My Seaway/Kiwi invoice totalled $1290.09 (variations due to exchange rate). The road freight is $400 less a $250 rebate, from memory. That will have the car dropped at the Melbourne depot. If you want it shipped to your house, the can arrange for another truck to move it depot -> your place. I had mine moved depot -> workshop as I wasn't keen on driving it myself and don't have access to a vehicle trailer.
The $1800 seems a bit high. Some customs agents charge for the aircon exemption even though they don't have to do anything. Perhaps just email Ben rather than guess? Jspec seem like straight up guys, you/we may have missed another fee somewhere?
Mark
  • Replies 95
Posted Images
okay, the 1800 j-spec estimates include:
The shipping estimate..bout 1000
Import & terminal security levy: $115
Quarantine and cleaning fee: $155
Import documentation fee: $35
Customs brokerage fee: $150
Quarantine charges and processing: $65
Trucking is free with kiwi, because J-spec have an arrangement with them and I get free trucking to melbourne :)
My car is also booked on the haul tropicana due to leave Osaka on the 4th and arrive in Brisbane on the 18th :)
thanks Mark, getting so excited now. She leaves in 2 days!!
jono, $2155? wow. Was the exchange rate really bad at the time? Its the only thing that I can think of, unless you had to get the car steam cleaned and powdered, but even then it sounds pretty high.
Hey Rylan, speaking of rust on your skyline, check these out...
Rear windscreen
These were taken on Friday. And the car doesn't have any visible rust elsewhere (ignoring the sills of course). Perhaps a good idea for all 89 drivers to have it checked. Apparently it is in between surface rust and body rust. Had we not caught it now, within a year it would have started eating through the roof
Where are you getting a replacement seal from? Nissan? My rear seal is stuffed so I wanna change it.......
The only rust i've found on mine so far is Underneath the car on the floor plan directly behind the front wheel about half a foot back.
Its where the grey sealant stuff has come away. Doesn't look major, maybe sand it back and bog....
Universal seals from Novus is the cheapest way to go. It still seals just the same as rubber from Mr Nissan but without the pricetag.
Have a talk with a painter in your area - there are a few anti-corrosive paints out there that will stop (or at least delay) the spread of surface rust. If you are able to sand it out, then switch off the comp Baze and get out into your garage ;)
thats no good Mark, how will you go about treating that? Is there any way of checking this without taking the seals out? (something I don't know how to do) Good luck with the repairs anyhow :)
In other news, according to the kiwi website, the Hual Tropicana has been delayed 2 days!!!!!!!! so it leaves on wednesday instead of today :) :cuss:
Thats the way importing is I suppose.
I was thinking about getting the underneath of the car sprayed with a sealant like 4wd owners do to prevent the spread.
not a good idea mate. underbody sealant just stops you from being able to see the rust. it will still rust, you just wont know until one day you fall through the floor and are then able to pedal your car flinstone style :)
best to get it treated properly, then paint it. like mark advised best off talking to a painter.
  • 3 weeks later...
just thought I'd just give you an update. the skyline's been in brizzy for a while now chillin in customs. It's being picked up at the brizzy terminal for transportation to Melbourne on monday, so I'm expecting it to be in here on Thursday or Friday :cheers::D:D:D
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
