Guys Girls and Doods (That means you Paul)
ONARUN has initiated plans for this Fridays Cruise so I thought I would rev it up a tad.
How about we try and get as many of you people along as possible. I know its been a while since many of you were out so a decent showing is definately in order.
Whos coming so far? I know i am (der):lol:
https://www.sau.com.au/forums/topic/726-friday-cruisemeeting-location/
  • Replies 109
Well i am definetly gonna be there nick so us White Warriors can show em that we mean business!!! :shake:
I'll catch up with ya b4 then hopefully oh yeah hows that gauge holder coming along???
Catch yas fri
Well yeah cause but i need to see it first and how much its gonna cost cause i need to put it off for about a week or so, dosh little thin at moment. But if u have one in (aint you got one in ur car?) stock i may have to buy it but if ya gotta order it especially, hold off till i have the cash!!!!
Tar nick!
Kabab will be coming also....
should be a great turnout...
Im thinking of maybe getting HPI along to one of these cruises...
Will make a few calls..... im sure a pack of wild skylines will interest them...
before calling can i get an idea of definates for this friday?
I am a definate for fri but i don't know about this (we dont exceed the speed limit) stuff Nick, speak for urself!!! ahaha ;)
And i agree the more there are the better it will be!! Lets just hope the f**ken rain doesnt decide to spoil the plans AGAIN!!!!!
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
