  • Replies 109
we'll be out prank.
Guys, Thornleigh maccas it is at 9:00 - 9:30.
Let's keep it simple and we won't get split up. We'll be heading out to Gosford up old road.
on a personal note, i drove for an hour this morning after getting minimal sleep last night, and i feel great.:burnout:
Damm,
I was hoping to get my clutch fixed in time for the cruise
to meet everyone, but as usually things have been delay
and can't make it.
Would have been nice to meet all of you and support the
RED DEVILS!
Oh wellz, have to wait till next time.
Or i might just at the last minute take my car with a
sliPPing clutch :uh-huh:
Cause it looks like it will be quiet a :crazy: turnout!
DLuded,
I will be taking my camera, but as previously stated, i wont be meeting up til later (if at all - if you guys are going upto gosford, i might give it a miss, no fun cruising up there on your own).
Also, I can't blow flames anymore. :cheers:
Ok...so I didn't bother reading the 2nd page :cheers:
I think I will also have to give it a miss as my ride prob won't be able to make it to thornleigh till 10 and if it's an old road run there's no point in trying to catch ya's up there...which is a bummer as I have 3-4 cars with me and a vid cam...
Hey gsi,,,why give it a miss,,,,we won't be turning around as soon as we get there,,,,plenty of time to catch up,,,Theres always the road home remember. Theres NO way you will miss us,,,,heaps of Mobile Numbers if you have a look....
Delta,Echo,Romeo,,,Old Bastard Out,,,
P.S. Prank We need you,,,,you are one of the White Boys....I have no Urmine,,, now you. It would be a sad day if the Reds win!!!!!.
Guest ManNGolf
Hiya guys.......me a newbie.....
im tagging along as well if its all kool.
hey are we going to do all 3 stages??.......since its a big group i think we should.
for those who have nicely lowered cars.......expect to bottom out on stage two.....otherwise just take it real slow on that stage.
rocking up in my gf's crx and hopefully get her to drive 2nd stage. i'll bring some guys along too. we all drive stock n/a cars.
for you's who come late.......i think u should proceed down to the mobil just b4 stage one and regroup there.
and for 1st timers to save confusion......cuz i know theres gonna be heaps of that!.........its the 2nd exit that you'll need to get off at the BEROWRA exit. then turn left and right and u'll hit the mobil.
c u's there.
oh and safe driving.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
