Hi, new to the SAU forum.
I'm starting to consider to sell my Silvia and upgrade to an R33 Sedan, either black or white, and was wondering what prices they demand now?
I am considering a turbo manual for now, but eventually i plan putting a twin turbo VH45DE motor in it, i was considering doing that to the silvia, but N/A, and nearly purchased the motor, had it all worked out, but i want something different and a bit more user friendly for more than one person, and where i live, all there is is silvia's.
Oh yeah, i'm not one of those people that posts once and leave, i plan on staying around, and if the project goes foward, ill try and become more computer literate and post photos of the progress.
Rough price's on R33 sedans please, greatly appreciated.
heres one i found earlier, that i quite like, and who knows, it might stay RB for longer than expected, thats why i want turbo aswell and manual.
http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/
The VH45DE is from the Nissan Infinity, i know it would be alot easier to stick with an RB25DET, and i love the sound of a nicely tuned one at full song, but i think the V8 twin turbo would be damn fun, sound awsome and be a little left of centre, when it comes to a skyline, also why i'm considering the Sedan over the Coupe
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/#findComment-1335494
The idea sound fine, and I am all for more sedans on the road but....
I doubt you would ever get it registered with a V8 in it (at least not in SA, I am not so sure about NSW) and the hassle for engineering and certification could cost a mint.
Have you measured to see if it will fit? (is the engin bay wide enough?)
Most sedans are automatic, but if you were to do this change it may be easier to install ae engine and transmissin from the infinity.
Prices vary a lot, so look around and you should find a nice ine for between 14 and 17,000.
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/#findComment-1335585
it is still an idea and definately not a go ahead yet, that motor setup is just something that i would love to do one day, not necessarily this car, for starters i'm just after a Manual, turbo sedan, either black or white, prefer black as it looks more sinister.
sorta guessed they were around that price, what about places to look for the car? suggested websites etc
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/#findComment-1335774
Yep, the 33 with the VQ45 is a friend of mine's car. Good luck making it twin turbo, there is literally no room down the side of the engine for anything. Sedans here usually go for a little less than coupe, but in Japan manual turbo sedans pull the same dollars, if not more, than coupes of the same vintage and quality. And manuals are quite hard to come by in sedans, I know I looked for my series 2 manual sedan for ages, and when I fianlly did find one that was suitable it pulled quite good $$$ at auction. But I am more than happy with it now :)
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/#findComment-1335820
thanks "gtst4d" i think this is the way i want to go, but lately i've been changing my mind every 3rd week, originally an RB20det in my S13, then SR20DET, then RB25DE, then VH45DE, then i got over the Sil, too impracticle, now i want a 4dr, and i thought of this car, 32 too old, 34 too much, JZX90 i would kill for, but $$$$, so i think the R33 4dr is the best all rounder that i want, must be manual and turbo, i wont put the V8 in this car
https://www.sau.com.au/forums/topic/72607-r33-sedan-price/#findComment-1337961
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
