Hey ppls.
Well, I'm about to start manufacture of the R33 AFM to TURBO reinforcement ducts.
Construction?
Mandrel bent pieces of Stainless steel, in a raw finsih, TIG welded. No polishing will be done, but if you want to do it when you recieve your pipe, the steel is ready for it. There will be sufficient pipe at either end to give a good seal to to the air. There will also be 2 x 1 inch beads of weld on the rim of each end of the pipe to give a non slip join.
You will need to purchase your one clamps depending on what style you want.
Currently the R33 jig have been fabicated and production will begin when all payments are in.
The price will be $110 each EXCLUDING postage.
I will work out postage with one person in each state and ship the ducts as a big bunch, and you can pick them up from that person. This means it's much easier for everyone and cheaper too. Obviously if you are out the back of Burke and you need a single shipment, or would just prefer a single shipment, this can also be worked out.
NOTE
The standard duct will not be able to be returned to standard after fitting the new section of pipe, but the duct will be such that it will be virtually invisible to the untrained eye.
People in so far, tell your mates who have R33s now, as I will only do this group buy once, no matter how much people want them!
RedlineGTR
Robo's
Pinoi-Boi-r33
Riceline
B1 Mr_Fanny
Wolverine
Xr8Eater
gtrGhosTDoGG11
burnfest
SydneyKid (Stagea R33)
ICE12 (Stagea R33)
SKYBEE
|PRESA|
tridentt150v
BLakniTE
SKYNUTS
GOR33
CMS Drifter
knore
drewecrome
halz....................PAID
R33 newbie
predator
R33_KRAZY
nacional
craz0
gts-wpn
LANFOH
Babia
r0ma
Zebbie
Race__24
abcent
R33impul
13_Devil
cd04
YogiR33...............PAID
Bazr33
Terminal
gR33ddy
tuitahi
tkch55
GTS33SOM
rob1981
Total R33 = 46
I will require all payments before I start the project because I'll be damned if I'm going to be stuck with any if people pull out after the material is bought and so on.
Check my trader rating, I'm not going to rip you off, I'm a committee member of Vic SAU, so they trust me, and so on and so on.
Before you ask, the price is the price. No question.
Please deposit the funds as such
Account Name
Peter N Blythe
Back of Melbourne/Westpac
BSB: 733 382
ACC: 586817
Amount $110
Please put your user name into the description of the deposit.
If you deposit the money at a bank, please ensure they also do this.
If you do not want the ducts and your name is in the list, please let me know so I'm not waiting on your payment.
I would like to apologise for the delay in getting this to the final stage, but I came up against a few obstacles on the way.
Thanks
BASS OUT
https://www.sau.com.au/forums/topic/72616-bass-junkys-r33-afm-to-turbo-ducts/
  • Replies 79
I dont understand, if its a replacemement pipe, why will my standard pipe be changed?
Oh, I take it that my current pipe is all rubber, so I will have to trim the ends off it and use them to attach to the rest of the system?
(My car is downstars at work, I will check it out later today and it should make sense)
I take it that it will change the induction noise somehow, in what way exactly?
bass i sent u my air duct 6 months ago so u could play around with it and even use it as your base model to work on i sent this for free to u i even paid for the postage i have asked u twice to send it back as im selling my old motor and that is a piece which im putting in with it so i ask again send back my air duct piece or at least PM me whats going on
Guest
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
