Bass Junky's R33 Afm To Turbo Ducts
Bass Junky
 Share
  • Replies 79
Hey guys.
Well, after a very long time, and much effort and much p1ss farting about and yadda yadda.
It seems that the way I want to do it simply ain't possible.
It will require hydroforming (high pressure steel shaping) and a lot of time, effort and money to do it.
The price would go up significantly, and we would be back at square one again.
I simply don't have the time to do it.
Im very sorry for all who were keen on getting one, as I was also very keen on having one for my car.
I guess I'll just have to call it. Maybe if I find some time and a different way of doing it, I will give it another go, but not until I have a piece in my hot little hands to work from.
Again, I'm very sorry. This project was meant to be a walk up start and easy, it sure looked that way on the video, but hey. Life ain't always easy, and not being any good at any welding or fabricating, I couldn't really do it myself.
Yogi33 and Halz, please PM me with your account details so I can refund your money to you.
BASS OUT :(
Hi Guys,
I may be able to get these made up. I own part in a Stainless steel merchant business in Nsw, i have asked 1 of my customers to have a look at this. As i sell all the pipes and bends i may be able to get them made up. The only problem i see is that if a front mount intercooler is fitted there may be a few variations to how the hoses (Breathers etc) on the intake pipe are fitted. On mine they have been moved or removed as i have seen on other cars, so if they are made up it will be hard to get it right for every car. Also i sell Aluminium pipe & Aluminium donut halves and may be able to get it cheaper in Aluminium. Will advise ASAP if practical.
Regards
tufsix
Hi All,
This is not a practical thing to make up as a group buy due to all the variations that different cars may need, eg (airbox position, aftermarket airfilter position & intercooler pipe position. They can be made up on a car to car basis but thats about it as it would be a problem to make them all up then have people saying they dont fit due to the above problems.
TM Autosports in Tuggerah NSW can make them and will be doing my R33 in the near future.
I assume this is the problem Bass was having making these up, it was worth a look at getting them all done together but not practical i dont think due to issues.
Regards
tufsix
The main issue I was facing was that the inside of the duct is not a common pipe size, making the sue of additional sections of steel pipe to join or hydroforming a nessecity, and making it very expensive, time consuming and difficult.
the price would have gone through the roof, and blah blah blah.
I'm thinking of buying an Apexi Super Suction Kit with all the whizz bangs on it, and then hacking up my stock duct and giving it a go in maybe a different manner, but I have to save up the cash for this expensive kit.
anywhoo. I'll let everyone know if I can do it later.
BASS OUT
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
