Hi guys,
I am a fresher in this forum, just joined today. I was planning to upgrade and am half thinking about a R34 GTT tiptronic. Hence had few enquiries:
- Whats the stock performance specs 0-100, 1/4 etc etc.
- Approx how much it wd cost to make it a 11-12s car.
-How upgradable the turbo is to a bigger replacement, power gain, cost.
-Pros/Cons of tiptronic.
If you could please help. I tried the search feature, but still bit confused.
Brief inputs on any of the above wd be appreciated.
Cheers
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/
Rough guess, 6.5 seconds and 14.2. Unofficial attempt at realistic figures.
Big $ difference between 11 and 12 seconds and a couple of different ways to get there.
Turbo is almost the same as R33 (same fitting anyway) so anything that fit that will fit R34. 100's of options at all different costs.
Tiptronic is easier in traffic, cheaper to upgrade (ie a shift kit costs less than an upgraded clutch 350-1000+) goes a little slower, can't use PowerFC for ECU upgrade.
Rather than a search, perhaps a few weeks browsing will sort you out for information. I read the forums for 3 months before I bought my car.
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1336466
Maybe
12.9 seconds will require 200 rwkw AT LEAST.
To get an R34 GTT at 200rwkw you will need the following.
Front Mount $1000
Power FC $1200
Boost controller $500
Fitting and tuning of all $700
Pineapples fitted $200
Fuel Pump fitted $400
That's about $4000
.THEORETICALLY. That should net a 12 second pass.
More likely with sticky rubber.
Into the 11s...... You need about 270 rwkw.
For that you need a brand name turbo ($3000 fitted) or highflow ($2000 fitted)
Cams $1200 fitted.
Retune of computer $500
Slicks or Nittos $800
That another $4500 - $5500
Into the 10s? Forget ot before you budget another $10 - $15k.
BASS OUT
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1336895
Manual would get a flat 6 i would think.
I just bought a 34gtt tiptronic. I guess u also
have to allow for increased drivetrain loss for
auto. I don't know what power the auto can take
apparently high temp is killer so fit a good cooler.
Tiptronic pro's: auto mode - same as any auto
tiptronic mode - good for compression slow downs,
hill climbs, its a novelty(steering wheel shifts are a
bit of a wank imho)
Cons: slower than manual to up/down shift, for me
at least (after owning for 2 weeks only) more difficult
to control than manual - sure Ill get used to it.
Manual is better apart from traffic stop starts, but
for an extra $5-6k i couldn't justify it. Esp when conversion
can be done for approx $3k.
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1337869
Thanks a lot everyone for all the inputs. Now I know more. Just planning ahead the finances I should prepare for. Looks like a big threshold credit cards required ;) . Money well spent for the R34 cause.
Also, I really just noticed the differemce between bodies of GTT and GTR (HOW could I not notice it before???)- the wide body of the GTR. THATS why they look sexier....
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1337980
Zymotic - It already has a good cooler for the transmission standard.
I actually find that possibly due to the cooler, it doesn't warm up fast enough.
You'l find that if you use the steering wheel buttons for a couple of months you'll never look back and wonder why you said it was a bit of a wank.
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1337983
Good, how much power before it goes bang?
Think I'm still getting used to the semi-auto type setup.
Maybe after i get used to the standard shift I'll trial the
wheel controls.
Do u use tiptronic mode for the track or drags?
Do u keep TCS on for track? (I've noticed when i give the
car a bit of stick one side of the rear seems to deaden [for
want of a better term] guess this is TCS at work, its wierd)
Had any dyno runs with your new hi flo?
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1338475
Hasn't gone bang yet and I'm over 200 rwkw.
I wouldn't even bother with the standard shift.
I use tiptronic everywhere, street, track, strip.
I also turn the Traction control off as soon as I start the car every time. Actually it's been broken for a week which is fine with me.
https://www.sau.com.au/forums/topic/72637-r34-gtt-enquiry/#findComment-1338780
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
