Does anyone know were I can get some side intrusion bars made up for my cefiro?
I only know of a place in queensland blah engineering that was mentioned on another thread, but he has been putting his prices up since his demand has obviously increased
Would prefer someone local to Perth, but anywere is good as long as its cheap
https://www.sau.com.au/forums/topic/72638-side-intrusion-bars/
