Thinking of replacing my hiflowed turbo to a GT35/40R 0.70 / 1.06 internally wastegated turbo.
Has anyone else done this conversion and can you advise the handling ie lag, dyno results, drivability, when boost comes on etc.
Currently do drags and circuit in SII GTS-T with intercooler, Power FC, Hiflow injectors, Z32 airflow meter, fuel pump, fuel pressure reg etc. - acheiving 302hp in third gear dyno. Would really appreciate hearing from someone who has gone through the exercise - good or bad???
Cheers
https://www.sau.com.au/forums/topic/72642-gt3540r/
I have been doing alot of research on this (haven't done it though) but in alot of cases, I wouldn't go for the 1.06ar exhaust housing, due to MASSIVE lag on a RB25.
I have a friend that has this turbo on his 95 supra (3.0l) and it hits full boost at 4200rpm. A guess at full boost on a rb25 would be 4500 - 5000rpm!!!
Thats way too much lag for me. I'm not an expert, but thats my opinion.
I hate lag, so I am going to eventually purchase something with a .63ar exhaust. If you are looking at big power, I'd go a .83ar exhaust.
Not sure on the Compressor size though..
SK might have an idea if he reads this thead.
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1340855
over 5k IMO
its bigger than my GT30 (4200rpm/16psi) and then your going bigger again on the Exh housing.
get a .82 and it'll be much nicer. Id even say a GT30 like mine. Its awesome for all forms of use
Hi Nismoid,
Thanks for the feedback. I was trying to keep the internal waste gate due to simplicity, cost etc. but seem to be only able to get the thing in a a/r1.06 exhaust. comp is a/r 0.7. I'll do some research on the GT30. Can you tell me your dyno result atrw and qtr mile times...much appreciated
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1341407
Thanks mafia,
I'm very concerned about lag as well... as I use the car on the circuit and need quick response as well as long legs in the straight. I want the best match for the engine capacity but am finding it very difficult to get a straight, independent answer...hence why I'd like to get feedback from anyone whose fitted an ungrade turbo and their actual results
Cheers
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1341420
so far, the all hailed shootout mode
330rwkw with a hybrid mix of fuel, not just normal PULP on 24psi
made around 270rwkw without the fuel and 17psi
and the show is on well and truly around 4200rpm-4500rpm.
Best match is the GT30 for an RB25, if you want bigger power then a GT35 is the go but it comes at a cost, and mine is quite nice on the street
Im heading for some drag this friday so i'll have a rough time/mph then
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1341441
Stealth,
Have you considered importing a HKS GT2835ProS (270-280rwkw) or HKS 3037ProS (300-320rwkw) from japland? They are both Internal gate. hence the PRO
Form memory they are around the 2.6k mark, unsure exactly the extra tax's and crap on top. I did look in to it a while back and have since forgot.
I 'think' stamp duty is only 3% on turbo's then you pay the GST. or is it the GST first then the stamp duty on that. :D
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1341453
my mate and i have just finished a conversion in his vl. its an rb25 with a gt35r/1.06 rear.
the engine is standard except for tomei poncams,splitfire coils,xf throttle and fuel and computer obviously.
it is running through a vl turbo 5 spd.also a 3:45 diff ratio
the engine makes 20 psi by 4200rpm and is producing 313rwkw.
personally i would recommend the .84 rear housing and a 4:11 diff
https://www.sau.com.au/forums/topic/72642-gt3540r/#findComment-1341610
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
