Can you source more than one Apexi turbo, if so one may suit my needs??? Could you PM me a price??
As for the VCT, as i understand it the RB25DE head does not use the VCT, which is the reason a lot of people use these heads as it simplifies the process a little.
I have read that the VCT can be used with the RB30 bottom end as mentioned above by tapping into oil pressure line.
People have used the RB20DET ECU to run a non VCT RB25/30 engine , but if you want to use the VCT it means aftermarket ECU, or maybe OE R33 with Power FC.
I understand that they use the same stud diameter but ive heard different people tell different tales about oil and water lines. Either way budget some $$$ for this and have it done when you have the block drilled and tapped for the new timing belt.
As for not worth the money, well if insurance and rego wasnt as issue i would be building an RB25/30. Even if your not chasing huge HP, extra 500cc help spool up larger turbos & plenty of locally developed perfromance parts for RB30 bottom. Hell you dont even really have to run aftermarket rods and pistons to make a lazy 250kws at the treads. Use a 6000rpm readline with 1bar of boost from a large turbo. Just make sure you use decent bearings, rod bolts etc, and have the OE stuff x-rayed and balanced/linished etc.
There are plent of VLs using 12 valve head making far more power then this and running in the low 10s and high 9s, some of the 10-11sec cars use std internals.
Look no further then the Sammut Bros old 300ZX drag car that ran an RB30, i recall it even beat Victor Bray one year. Dont know extent of mods though! Nizpro also has a long list of 9-11 sec streetable VLs.
what gearbox and diff do they use? cos i'm sure a standard skyline box and diff wouldn't hack much more than 300kw at the treads... especially not with a few hard launches!
does the VCT make that much of a difference when talking RB30DET? Where would you notice the power difference, bottom or top end?
Thanks
Andrew
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
