  • Replies 102
The Nur is not a real Nur. As far as I know there are only 2 of them in the country, a third one arrives fairly soon. The guy found out about the event the night before and took it to a carwash that morning where they did a very average job on it.
I think only an owner knows how to get his/her car properly clean.
Satanic said he put 4 hours into cleaning his car, which he thought was a lot. I put 6 into mine to not even enter it. I know some would have put up around 20 over a few days.
The Judges could tell who had put the effort into cleaning their car and the points were appropriately awarded.
i put about 2 days into cleaning mine. took me 4hrs the wheels alone!
jayce, your not working are you? it would explain why you've posted so much over the last couple of days, ya bum!
Breather between old job and new job...
Does anyone have any pictures of it front on where you can see the bonnet? From the quick glimpses I have seen, it doesnt have the NACA duct on the bonnet which would mean its not even a V-spec II (unless its had the bonnet replaced)?
Still, id give my nuts for a BNR34 :wassup:
Oooh and gracer still exists... I havnt seen that car around for a while, possibly one of my favourite GTR's of all time (not sure why, I just love it).
"GRACER" started life as an R33 GTS-T,by the way...
A-HA! The game is up! I just knew  he was a poser of the highest order...Is he on the forums at all?
That's a bit harsh. Damn Struggletown dwellers... Just kidding.
I had a bit of a chat with the owner and he admitted to me in his first sentence that it wasn't a real one. Also I didn't ask him where he bought it but I think I know the car from before. Powerplay imported it and then it belonged to a guy in Qld. Powerplay then resold it probably to this guy. It was the Qld guy who turned it into a Nur.
He is not on the forums but he did join the club on sunday. Owns a wrecking yard I think.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
