89 Nissan Laurel
Rb20det 5 speed
white / blue pearl
Engine:
Rb20det
3" stainless cat back exhaust
3" mild steal double dump off turbo to cat
Trust Front mount intercooler
HKS mushroom POD
OS Geiken Twin Plate clutch and lightened Flywheel
Exterior:
4/5 stud 16" mesh wheels
Wing deleted
Sunroof
frong guards rolled
Interior:
Shift knob
Aftermarket handbrake lever thingy!
Boost and water temp guage
Pioneer Cd player and speakers
Handling:
GAB rear lowered suspension (damper adjustable)
Lowered front suspension
new polyurethane sway bar bushes
Registered and 107 _ _ _ klms on it.
NEW TIMING BELT DONE 16/09/05
$12 000 with rwc and 6 months rego as of this week. Please note now has a stock front bar to pass roadworthy.
0401 669 900 [email protected]
Pics coming shortly.
Cheers
Jayson
Edited by Mase
https://www.sau.com.au/forums/topic/72710-fs-nissan-laurel-rb20det-5-spd/
  • 1 month later...
Will sell with the 18's instead for an extra grand. These wheels clear skyline callipers without any spacers and allow a disc and calliper upgrade without having to go full five stud. New tyres on the front, good tyres on the back. Come with centre caps but i prefer without personally.
  • 3 weeks later...
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
