  • Replies 49
cool, Id be interested to see that graph
I'll post it tonight...
Hi RiggaP..
With that setup, i would expect less power on a hot day due to the stock intercooler with 13psi...
The turbo wouldnt like this long term i would suspect..
Additionally, the bleeder i daresay wouldnt hold the 13psi up the top end...
I would expect less power on a hot day with any car. Just another reason why dyno figures cant really be trusted. This doesnt alter the fact that I got a reading of 195rwkw :P
True, long term exposure to 13psi is probably tempting fate, but I'll cross that bridge when I get to it. I've been running 13psi for over 12 months now.
The bleeder I'm using actually holds boost better than an AVCR. BMT Performance proved this to me with their dyno :D
shootout mode is ok though as is take the temps into account and ajusts the values to compensate.
  • 1 month later...
So based on these round figures my set-up would make?
Power Fc
AVCR set to 12 psi
3"cat back, 3" catco hi flow cat, 3" dump pipe with splitter front pipe
pod filter
GFB BOV
new timing belt
z32 air flow meter
also how much would a front mount add?
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
