Hey Guys,
Looking to get rid of my RB30ET bottom end. Comes with oil pump, sump, block, pistons (Ceramic coated), rods, crank and a few other bits and pieces. Block has been out of the car for a while, but I oil coated everthing.
This engine had about 10,000 on the clock. Block was honed, balanced about 18 months ago, sorry no reciepts.
Needs new bearings and rings, as I pulled it all down to rebuild but have never got around to doing so.
Asking: $300
I can also supply an rb26 head (needs one new valve). Comes with Cam, Valley and Timing belt covers aswell as complete valve train
Asking: $500
Local Sale only pick up from Nerang, Gold Coast.
https://www.sau.com.au/forums/topic/72733-rb30et-bottom-end-rb26-head/
Guest two.06l
Hey Guys,
Asking: $300
I can also supply an rb26 head (needs one new valve for $500). Comes with Cam, Valley and Timing belt covers aswell as complete valve train
will take them both but in Newcastle N.S.W. can arrange freight
    • Agree with Rob. I recently did mine and replacing with a brand new unit made the most sense compared with rebuilding my existing gearbox.
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
