Don't know current models, but last year, JVC slaughtered the competition cause of it's features for the price. Most my friends run either JVC or pioneer. I run JVC on my good system, and pioneer on my crap system. The JVC is much better. It feels better made (buttons etc) All my friends that have had both systems agree.
JVC are also really easy to use - great layout. Pioneer tend to be a bit wierd in it's layout, but you get used to it. If I replace the pioneer I wouldn't consider anything other than a JVC due to my previous experiences.
I hate Sony with a passion. haha Can't stand them.
I've got nothing but praise for JVC, my KD-LH2000 has been great and hasn't skipped a beat from 3 years of constant and severe use :O
I've been very impressed with the features, and we're talking about a way superceded model here, the newer versions are absolutely tops!!!
Lots of places are now doing run-out sales on the KD-SHX900 this would have to be one of the best value for money head units around...I want one!
For the guy with the broken JVC, try the local JVC service centre at http://www.jvc.com.au/
I've had to put off my mp3 player for awhile cos my engine is giving me dramas ;)
but it sounds like the JVC unit is the go when i get some more cash!
some of you guys didn't mention the model JVC unit that you are using, what model would be most recommended for a good all round performer?
thanks again
sam
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
    • Haha, the big brain move is to buy a second set of headlights to clean up or retrofit. I definitely don't have one sitting in a cupboard that hasn't been touched since it arrived. Just have to ignore the intrusive thoughts that suggest the second set is not quite as good as it could be and to buy a third set that the job would definitely get done with
    • Nah I'm talking about the GTS-t with 15" wheels and single piston brakes.  I've seen them pop up occasionally over the years. You can see it in the brochures. Most were early models (aka Series 1).
