I've got an R32 GTR and after having the front suspension out today, noticed that the front left (passenger side) CV is leaking greasy crap quite badly (it has sprayed off onto the dump pipe creating a nice burnt look).
A couple of questions:
1. are they expensive, and can I get them from Nissan?
2. are they tough to change, for a guy who is spanner-inept (ie. the most i can do is change my suspension over...) or best left for someone with more skill and tallent...?
3. should I do both L & R at the same time considering that if one is gone the other isn't far behind?
Thanks ;)
https://www.sau.com.au/forums/topic/72803-cv-joints-leaking-expensive/
The Passenger side? Make sure its not the Powersteering fluid leaking onto it and making it look like its busted.
I'm pretty sure it's not PS - there is packing grease around the CV and looks like spray grease all around it. P/S would be too thin to solidify like that.
How can I tell if the CV is shat or if it is just the boot that needs replacing? can you repack the CVs? I remember a thread recently talking about repacking vs. new CVs but can't for the life of me search it out! :cheers:
That would be for the boots, not including the cv. cv should be ok provided the boot hasnt been torn for too long and run dry/dirt/muck etc
Car would not have done more than 500kms with torn boots. There is no noise or knocking from the CV, so I assume I can get the boots replaced and repacked?
i have a question relating.
i think
i find sometimes when i turn, i get grinding feeling through the steering wheel.
now the other day i had the car up and noticed a torn boot, what are the odds this is the issue??
and is there anything to watch out for if changing the boots?
CV boots and steering rack boots are two different things.. they are talking front driveshaft in GTR.. gts-t just has a steering rack.. If you want any tips on changing the steering rack boots then PM me, as I did it recently.
hi there marcus....the main problem you will have is you will need to undo the nut in the center of the drive shaft and this i think from memory is a 35mm socket of which you will need to use a rattle gun to undo...you will also have to undo the lower balljoint to pivot the hub assy away far enough to get the shaft out,then you will need to disassemble the driveshaft and wash all the old grease out,fit the new boots repack and reassemble them....its a very dirty job
Hmmm best left for someone with a. more patience b. more skill c. more time, then.
Got quoted from Nissan 66ea for the inner and 66ea for the outer boots. So all four boots for front $264.
A shop quoted me 3.5 hours to do both sides - remove, repack, replace. Is this reasonable?
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
