original airbox was too restrictive with the panel filter.
installed a pod filter a while ago to my NA it was an improvement, but it was just sitting there and seemed very sluggish due to the heat from the engine.
I then decided to make a heatshield to try and make the most of it.
template was made with cardboard - made about 3-4 of these, continously trial fitting.
transferred the cardboard template onto aluminum sheeting
mounted brackets to hold the sheeting in place
insulation foil on both sides to keep engine heat away from pod.
I have yet to do a temperature check, but after a fairly spirited drive for 20mins, and placing hands on either side of the heatshield - a large difference in temperature was apparent.
End Result:
https://www.sau.com.au/forums/topic/72817-got-a-pod-have-a-heatshield/
  • 1 year later...
Gday Eug,
I don't know if it is just me but there are no picures in your explanation (i'm running firefox so there should be no problem).
I am actually in the process of building a heat shield out of alluminium for my freshly installed POD.
I would like to see how you mounted yours :PBJ:
Where did you get your insulation from?
Any probs with cops so far?
Thanks a lot mate :D
hey guys, photos got deleted off the gallery when christian made some changes to the site...
i dont know if i can dig up any photos, i'll try to hunt for them.
basically i had an aluminum sheet 1-2mm thick, and had them bent at appropiate places to have the AFM coming in at the right angle. i then had 90º brackets made up and attached. the aluminum sheet was then covered in a foam/foil adhesive on both sides.
basically it goes like this:
foil/foam - aluminum sheet - foam/foil
the sheet had a hole just enough for the lip of the afm to peek through - the pod was then bolted.
i also had a small section off the top cut out to re-attach the snorkel from the original airbox... its a bit home-spec, but it its neat and does the job. and will only cost you something like $20.
you can get the insulation from places like clark rubber. i've never had the fuzz check my car let alone my engine bay, so i cant comment there...
ok so i've got all the materials i need. (except the heat insulation stuff). i am also trial fitting cardboard templates...but i fear that these cardboard "rough copies" are gonna make the finished product look shit.
Eug, any tips on how exactly to make it look half decent.
also, what car is yours? i have a turbo R33. i'm sure with yours being NA, whatever it is, you'll have less piping to worry about.
if you could get the pics up, that would help!
ooh...if you still have the cardboard templates too, put them up!
cheers
andy
Edited by sedanlover
ok so i'm well on my way to completing my very own heat sheild :)
i might even be nice and share with you all how i did it. (i took pics :()
stay tuned for a new topic... coming to a DIY forum near you!!! :P
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
