  • Replies 128
Originally posted by XrSiSt
Biatch!! i knew i had no chance against u... oh wellz.. third
gear decided to go missing twice!!
/eric in the evil voice.. "I'll be back.... until next time..."
Dont worry Eric. I owned him for you.
I was part throttle and had no 4wd at all and I still beat him hahaha
pwahahah Dave.. wat did i say last nite.. 50 post in like 20
minutes.. Man i rock up at 9am.. and there's already 37 post.. wtf
hahahaha
Thanks to all for coming last night. it was great fun.. FRISKI and
his brother are abit on the quiet side.. but they had fun... The
Don King guy aka Jimmy said u bunch are all ghey!! hahah j/k
He said it was good hanging out with you peoples and asked
why don't have a skirmish thing going.. hahaha
I don't remember one time that i wasn't cracking up last night..
and there were so many conversations... ur mind goes wacko!
Was good to finally meet George aka XCUZME and Nick aka BY BY
last night.. Thanks to the guys from the east come down for some
pizza.. hmm...... which reminds me.. no more pizza for the next
year okies!!! :lol: RONIN.. great to see u once again..
Frank and Mark were getting with their female side...
Great to see all the usuals support the WeSt-SyDe!!!
Minh.. was good to see u there... and Paul mate.. no comment..
:P
Dave.. still not happy jan.. waiting to see that beast of ur's...
me <3 traction control
donnie, all that pizza going to waste...tsk tsk tsk....
:bahaha:
nah minh that's my call, URINE IS YELLOWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWW
WWWWWWWWWWWWWWWWWW
but i'll license it out, its all bling bling...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
