My R32 GTS4 coupe has just broken a wire cable in the driver's door electric window assembly. It still has power etc and when you look down into it you can see the wire drum revolving with the broken end of wire rotating around it. I've pulled the interior trim off the door but the area where the wire is is inside the structural part. This wire is what drives the window go up and down.
How do you fix this sort of thing? Or where I can find a replacement part? :rofl:
https://www.sau.com.au/forums/topic/72867-electric-window-issues-r32/
I recently fixed an R31 mechanism with 225lb steel trace from the fishing shop and it works sweet.......BUT
the job was a major pain and I only did it cos I couldn't get a new mechanism. (The 31 one is very similar to the 32 but different enough not to fit. I would have happily paid $150 for a new mechanism instead of repairing it.
My advice comes with a hidden agenda though... I've got the one you need 4 sale!
pm me if interested, but check to see if you can get a cheap one locally
