Sorry Hicks I'd already posted on the other thread "Wednesday Night Drags". Well for my first go it wasn't too bad but my launch is embarrassing, even V8's took off harder than me, so there's plenty of room for improvement and enough horsepower to get the mid-13's, I'll be there next Wednesday, hope you can make it with your new clutch Hicks.
Best time 13.9, best top speed 170km/hr, best 60' 2.3 (which is shit) and we wont even discuss my reaction time, I must have been asleep on some runs.
But it was great fun and I'm hanging out to improve my times.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7287-plex-tonight/#findComment-107273
You've got a pretty nice terminal speed though, your just loosing it at the start. But 2.3 60ft isn't that bad, my first 13.8 i had a speed of 2.1, but my 13.7 was a 2.3. And that was during the day!! I think that the track was really grippy though due to the heat.
https://www.sau.com.au/forums/topic/7287-plex-tonight/#findComment-107404
Yeah, everyone keeps telling me, but when I get the stage lights I'm too busy trying to get my revs right that by the time I look up I see it's turned green, then I nail it and loose traction. I think towards the end I was starting to feel more comfortable, it was also cooler, and beginning to get my shit together.
It certainly doesn't look hard as a spectator, but driving is a bit more difficult. I think next week I'll be better prepared and my times should drop, with luck.
Thanks for the tips though.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7287-plex-tonight/#findComment-107515
Steve,
I don't think Wolf has launch control planned, but they are bringing out a firmware update for Anti-lag, so I think the Autronic SM2 is the only one I know with launch control. I have traction control on my car, but I leave this disabled as you end up going slower.
I don't think I need the launch control, I just need more practice. I was also getting alot of diff bounce, so I will try the pineapples to see if that can improve the launch.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7287-plex-tonight/#findComment-107620
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
