Exaust, fuel pump, fuel reg, 12psi off a bleed valve, and a bit of pipe for some cold air to the pod. 145rwkw. Keeping in mind that was a hot day, and the bit of pipe for cold air does bugger all to nothing on a dyno.
My goal is rb30 and 300rwkw. :rofl: and to be the car to be a bit of a track monster.
I got 260rwhp at 0.6 bar. RB20 Bottom end, RB25 Top end
Umm... Worked internals, 3inch exaust, FMIC, powers turbo, Custom plenem, GTR injectors, Shitty turbosmart boost controller, Custom manifold(but there was a leak wen i got it dyno'd), Stock ecu been remapped, .
what sort of gains do you guys get from just a FMIC?
i found it takes a little longer to pressurise the bigger front mount cooler but the affects are definately there, just takes a bit longer to hit full boost but when it does you can notice it. my opinion anywho. :kick:
  • 4 weeks later...
hey guys.
just joined up on here tonight.
i got 210rwkw in my ceffy
power fc .hks 2530.tomei cams etc
Did you buy phil's cefiro? I've been out drftn with him a few times? If it was that was lowrollaboy's car.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
