Originally posted by BROKEN
mine peaks at 14psi to make 143kw at the wheels
good turbo for a 4cyl i reckon :P
Nah Lil SR20s and CA18s come with the same T25
RBs need something bigger even my CA18 Has a T3 on it now..
Even a T3 on your RB JimiH isnt the BEST alternative...
But your right they are known for generally running out of puff up high!
Dont be like that champ.....
I dont need to read anything to say that they are totally different.
Firstly the size of the compressor cases and exhaust cases are smaller on a T25 and support smaller turbine and comp wheels!
The inlet and outlet of comp housings are much different!
Turbine dump is different........everything is different!
Your probably thinking about where the turbine fits on to the Ex manifold (Bolt Pattern) 4 bolts in a rectangular fashion...These are the same.....And they call it a T3 Pattern.
As for comparing a T28(R33) to T3(Z32) Ive measured the comp wheel and housing to be slightly better on the T28
But the Exhaust side of the T3 is bigger and so is the wheel actually a fair bit so this will give heaps of top end so i think it would be ok for an upgrade on an R32 but not much point on the 33 plus u will be modifying a fair bit to get average gains
:P
heheheh yeh I know :P :bahaha:
mind you ... when his car is sorted out ..... goodbye jimi :)
the turbo + cooler will definitely be in before the end of january ... i'm hoping maybe the first or second week of january will be fitment week :)
Originally posted by kabab
i wouldn't bother with a vg30 they are a 8 year old design as well try getting a R33 gtst turbo or a S15 turbo, much better options less lag more power !!
You cant boost them up
My r33 doesnt have a problem with the 10 yr old design T3/T4 the guys will confim that :P
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
