I've removed everything in order to replace timing belt so I'm at the stage of loosening that big bolt on the harmonic balancer.
I've put it in 4th gear handbrake on. When I go to turn it anti clockwise with a big bar the crank turns a little before resisting ( like 10 degrees). Things then tighten and I might be able to loosen it though I'm afraid of snapping the belt etc.
My belt has about 10-15mm movement back and forth between the longest gap between pulleys. I can almost pull the belt off the camshaft pulleys without loosening anything it is that loose.
Just wondering whether to heave ho on it or be very careful. I just don't want to bend a valve on it while I'm trying to loosen this bolt.
Thanks
if you do that whilst in gear and handbrake on, you WILL damage your gearbox. Do it by getting a breaker bar, or if you think your ratchet is strong enough - add an extension pipe to the handle, place the end of the bar UNDER the left (passenger) chassis rail and while holding the head of the ratchet in place (so that it doesn't fall off), get someone to hit the key. If you search you will also find a huge thread that already covers this and all the questions you need to know. As for the valve thing, as long as the belt is still on, the camshafts turn with the crank so you don't have to worry about bending valves.
I haven't seen anyone else besides you mentioning about the damage to your gearbox from the method I mentioned - I have searched.... Wouldn't the clutch slip rather than damage your gearbox? Maybe you are right, I am just asking
I have searched and I thought this was the safest method. I really don't want my hand to be under there when someone hits the starter, even if coil is disconnected..
If the breaker bar breaks it could hit me or the car etc.
Thanks
Then get a rattle gun and remove the radiator and air con rad also. Then you will be able to get it.
There is also a tool you can buy for about $45 which is designed to do the same job without the removal of all these items. You should be able to get it from repco. You will need a large hammer to operate it.
On the gearbox issue, it will damage your gearbox, trust me...don't try it.
I have seen a gearbox DESTROYED , not damaged, by doing it this way. I have also been told by numerous gearbox specialists of the damage that can be caused. I am a mechanic and see this stuff all the time. I witnessed another mechanic attempt the same method and all you could hear was POP and then the car would not drive again. Gearbox came out, was sent to the local gearbox shop and was told that by forcing the gearbox in that way was what caused the damage.
Thanks for the advice then. I'm suprised not more people mention it. Lucky I didn't go to hard on it.
I might try the chassis rail trick then.. Should I just unlpug the big connector on top of the rocker cover that gives the electrical signa to the individual coil packs?
Then hit the starter for a split second.
no need to disconnect anything. Just hit the key. you only want to use the force of the motor to crack the nut so only a split second is required. It is definately by far the best method short of a rattle gun and some times better. As long as you hold the head of the wrench on there it won't hit you in the face or come off. It is kinda frightening at first but when you have done a few hundred you get used to it. Make sure the extension is under the chassis rail and not something soft that can move. Close your eyes and brace yourself, then hit the key and she comes straight off. You also want to make sure your ratchet is strong enough otherwise it will break. A breaker bar is preferable to a ratchet.
sorry about the inbox full, try again
I have a long breaker bar with a swivel head. It is a bout a metre long I would say. When I undo axle nuts (about 200Nm) I can see it flexxing which is also scary.
I hope it won't break. I might put on my welding face mask, gloves and overalls. Be a real woos.
It's safer to disconnect the ignition source though right? So it has no chance of kicking the motor over.
I suppose so. I have never needed to crank it that long but yeah, just unplug the grey plug located infront of the ignition module. It should also be attached to the same place as the small earth wire.
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
