I cant seem to find any one who sells the replacemens HID bulbs (i also dont know want type of HID bulbs i need). I have look at Autobarn, Supercheap, *cough* k-mart, and even e-bay... No one in brisbane seems to sell them. Does anyone here know ???
  • 1 year later...
I was told Bursons want about $280 PER Globe, and Honda wanted nearly $1000 for a set (Same as accord)....
I ended up getting genuine philips D2S from USA the other day, i actually ordered a spare set incase anyone needed some.....
Cool thanks for the reply.
My car was complied in 1999 so I am yet to find out if it has teh factory Xenons or they were converted to Halogens. Since my car has zero lights at the front (aside from indicators) I am yet to find out, I think it is a fuse or perhaps a connection under the dahs? I'll have to find out....
take the bulb out and check .... its easy, should take 2mins.... maybe afew more if you have stuff in the way like me.
Will do, thanks for your help ferni. Only picked it up yesterday so I need to find the time to investigate. Cheers.
It should have the xenons, under the old system they left them alone.
Its a bit suss that they both stopped working, it sounds like a fuse or even the combo switch, not the globes.
Do you have high beams?
To test them you don't even have to take them out , just power them up from any 12 volt battery.
Looks like the bulbs are farked and they are xenons. I have one passengers side high beam, that's it! ;)
The car has done so little kms over the years it has basically been undermaintained in some aspects as the owner didn't bother changing globes since he didn't drive at night! I looked at the globe and they must be xenons, they have what appears to be a little chamber in the globe. Xenons are charged gas right? I assume the chamber is for the gas then? (I may be way off ;) )...
Its only the low beams that are HID, high beams should be hals. You can't see the globe unless you pull it off, they should have projector lens .
what wrxhoon said expecially with testing them with 12V also remember not to touch the bulb itself
How do you change the bulbs on headlights?
I have a busted bulb on my right one.
I have no clue on how to change them.
Till then no driving
Turn the plastic caps HARD and they will pop off. Scrape the fark out of your hand as you get the bulb out. Scrape the fark out of your hard as you replace them, refit caps and it's all done.
My lights still aren't working, haven't replaced the xenon bulbs since I couldn't find any to buy. Drivers side lights do not work at all. I think I my have to pay an auto elect, fuse, bulbs etc. are all OK. Everything appears to be fine... it's got me buggered. So annoying as it is the only thing I have to do before I take it over rego! Currently has no plates on it because it was brought up from Victoria. I'm hanging to drive it!
If your globes and fuses are OK then more than likely its the combo switch.
It's making a definite 'clicking' noise from somewhere when the lights are 'on', didn't sound too flash.
Thanks for the advice, I'll do a search on the combo switch. :rolleyes:
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
