i have lots of stuff to get rid of
r43 gtt dash only $145 no vents or guages
r34 insterement cluster $255
turbosmart boost controller dual stage $ 250 new
saas stering weel $300 new
R32 clutch slave has been sleved recond $ 60
r 33 Tail shaft yoke $60
All R34 dash Vents $ 50 each have mose in good nick
R33 ele speedo drive $ 40
R33 Turbo gbox mechinicaal speedo drive $ 60 new
r33 non turbo 5 spd gearbos same as r32 gtst but different ratios $ 150 little noisy no scynro problems
6 yokahama v102 tyres suit drifting 235/40/18 very worn suit drifting ir burnouts $ 20 each
r32 gtst cluster make offer $200
r32 gtst turbo make offers sold
r33 turbo 5 spd std shifter $50 sold
i also know a dude with r34 gtt injectors and air flo meter offers
and water temp sensor rb $35
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/
give us a clue on how much ya afta....... you said make an offer....... thats was a start point.... you tell me wot your looking at and we'll see wot we can come too... just a question, is the speedo mechanical drive or electrical?
and yes im still interested........
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348230
i have both 33 mec and elec speedo drives sorry the insterement cluster i would want over 150 for it it is the one out of my car i got one of those 260 klm jobs the r32 is mec maybee u should look at the r34 one i have 4 sale
a bit more modern
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348266
neo32: I am considering buying an S13 silvia with RB20DET conversion, however they haven't wired up the tacho properly and are having probs getting it to work. Do you know if the R32 GTS-T instrument cluster would fit into the S13 dash? It should wire up properly too? Also how many klms on it? I'm in Brisbane so could pick up
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348500
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
