i have lots of stuff to get rid of
r43 gtt dash only $145 no vents or guages
r34 insterement cluster $255
turbosmart boost controller dual stage $ 250 new
saas stering weel $300 new
R32 clutch slave has been sleved recond $ 60
r 33 Tail shaft yoke $60
All R34 dash Vents $ 50 each have mose in good nick
R33 ele speedo drive $ 40
R33 Turbo gbox mechinicaal speedo drive $ 60 new
r33 non turbo 5 spd gearbos same as r32 gtst but different ratios $ 150 little noisy no scynro problems
6 yokahama v102 tyres suit drifting 235/40/18 very worn suit drifting ir burnouts $ 20 each
r32 gtst cluster make offer $200
r32 gtst turbo make offers sold
r33 turbo 5 spd std shifter $50 sold
i also know a dude with r34 gtt injectors and air flo meter offers
and water temp sensor rb $35
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/
give us a clue on how much ya afta....... you said make an offer....... thats was a start point.... you tell me wot your looking at and we'll see wot we can come too... just a question, is the speedo mechanical drive or electrical?
and yes im still interested........
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348230
i have both 33 mec and elec speedo drives sorry the insterement cluster i would want over 150 for it it is the one out of my car i got one of those 260 klm jobs the r32 is mec maybee u should look at the r34 one i have 4 sale
a bit more modern
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348266
neo32: I am considering buying an S13 silvia with RB20DET conversion, however they haven't wired up the tacho properly and are having probs getting it to work. Do you know if the R32 GTS-T instrument cluster would fit into the S13 dash? It should wire up properly too? Also how many klms on it? I'm in Brisbane so could pick up
https://www.sau.com.au/forums/topic/72901-bits-and-pieces/#findComment-1348500
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
    • That could very well be the thermistor, but the ECU only sees Volts. VDO don't seem to provide a 0-5 volt curve, only the resistance curve.... (or line).
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
