I'm in Narre Warren so I figured I would head on down to Freeway Car Audio to ask about replacing all the original (and now very stuffed) factory speakers. The guy I spoke to said they can't fit 6x9" in the rear, something to do with they wont hack into the parcel shelf or metalwork underneath, fine..
For the rears he suggested Alpine SPS-170A's and for the fronts he suggested Apline SPS-171A's (split system). Original grills will be used so it will still look stock. The amp for this would be an Alpine MRP-F240.
For decent bass he suggested an Apline SWS-1242D with enclosure and Alpine MRP-M350 amp.
They'll install sound deadening material, baffles and a line converter (if necessary) and do the install for around $2200.
Is that a decent price? Does anyone have any feedback about these guys? I know they have been around for years and a guy at the Alpine stand I spoke to had just got his car back from them and was happy with the quality of work.
Opinions?
mike
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/
Supplier, Installed and Fitted at garys car radio in preston:
1 x SPR176A - Front Door Splits, Mounted in stock location with tweeter mirror mounted
1 X SPS170A - Rear Coax Speakers, in stock speaker location
2 X WS1241 - 12" Type S Subs in Boot (Sub Box)
1 X MRP-M350 - Monobloc amp for both subs
1 X MRP-F240 - Four channel amp for front splits and rears (pretty sure its this model)
1 X CDA-9807 - New head unit
- 1 x Pioneer CD-MP3550 Trade in for $250
Total price: $1840 complete, they supplied a free Alpine AI-Net Cable as well to hook up my DVD Player to the system.
After all the stereo crap I looked at and people I spoke to:
Garys Car Radio = The best, Preston store is tops, well worth the trip. I'll come down if u wanna check it out. 6x9's are crap. Get 2 x Subs in the boot, Facing outwards. Don't mount the subs facing towards the front of the car. Get a seperate amp for the front/rears and another amp for subs. Replace the head unit you have. If you don't then youll have to use line in adapters for sub output and it wont be anywhere near as good. The CDA 9807 (or whatever head unit you get) should have 4v preout for the sub output. Also your stocker head unit probably doesn't have any amp line out's so they have to hack up in-line adapters which wont be as good. If your spending $$$ then buy qualiy stuff and sell the stocker head unit.
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/#findComment-1340206
if your coming on the new members cruise next week ill show you how my setup sounds. also when your getting demo's of stereos and setups listen to original audio cd's and not burnt discs or mp3 cd's. also try and get some jazz or classical audio cd's, great for sound reprocussion tests. my setup sounds bloody awesome with original audio cd's or even tracks direct from from vinyl off my turntables at home burnt to cd audio
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/#findComment-1340222
Hi Paul,
That sounds like a damned good price compared to what I was quoted, especially when you consider that I am only going with a single subwoofer and i wasn't being quoted on a replacement head unit.
The only problem with Gary's Car Radio is the location, i'm in Narre Warren and Preston is a long long way, especially as i'm guessing they'll want the car for at least a whole day.
Going to have to think about this, damn, isnt anything easy anymore :cheers:
mike
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/#findComment-1343986
I'm still waiting to get access to the members area but once I can get in and know where and when, I should be there. Look forward to hearing your setup, as its close to what I want except i'll only go a single subby.
mike
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/#findComment-1343994
i just got a digital design setup with 12" sub, 400wrms 4ch amp, and 6.5 splits for both front and rear for $1300
thats just a single amp and sub setup with just the same loudness/quaility, maybe even better for alot cheaper
so if i were you i'd shop around a bit more before go forking out that kinda dosh
-Ruffels
https://www.sau.com.au/forums/topic/72907-speaker-upgrades/#findComment-1344096
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
