hey guys, got two heads for sale. 1 DET and 1 DE, both from R33.
***both SOLD***
DET Head:
Comes with inlet manifold, Fuel Rail and injectors, rocker covers, both cams and all sensors seen in pictures. Still assembled on block. Welcome to come n check $450
If u want the whole engine, take it...$550, low compression. Old engine from Swap. pics of engine are dirty cos of spilt oil from mechanics, spilt the tray down the side of it, cleanable.
Has done aprox 115,000km
***SOLD***
DE Head:
Comes with inlet manifold, Fuel Rail and injectors, rocker + coil covers, Loom + ECU, throttle body, coil packs + igniter module, CAS, both cams, extractors. might have missed some things, just check pics or PM for questions.
Only problem is, is that the cams have been removed, becos i was going to use the in cam for current engine, but then i couldn;t be bothered anymore, still included in the package tho, just have to get them put in again. No mechanical faults, did turbo engine conversion. $550
this is also still assembled to block, with all sensors and hoses etc still attached as seen in pictures. so take the whole thing for $650 if u like.
Has done approx. 78,000km
***SOLD***
Pictures here..... click to enlarge.
http://seahorse.strayed.net/misc/RB25Heads.html
Need to get rid of them to make room. so i really can;t be bothered to sell little bits and pieces, unless of cos i have enough people interested, so i can still get rid of the majority.
OK, thanks for reading.
-Henry
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/
would you consider shipping the DE head to WA?
Im not interested in the block, extractors, loom orECU
just everything else with the head including cams and inlet manifold
umm yea will consider, just that still waiting for someone to reply wether he will take de engine or not. get back to you asap.
i;m gettin prices for freight tomorrow for someone in melb.
i'll ask about WA as well. Whats your postcode?
also, anyone know any cheap places? last time i got a pallet of car parts shipped up from victoria, for 70bux...is that any good? if u know a better place, tell me and i'll ask them for price.
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342160
cant really help you on freight prices but I guess $70 for a pallet sounds like a decent deal
as for my poscode is 6000
hmmm ok.
will ask for u anyways, then let u know as soon as i find out about other buyer.
oh. i frogot to mention but, i thoguht it wasn't nessacery...but jsut in case, shipping will be at buyer cost,
sorry if confused anyone
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342162
got some prices for the shipping. its just that i;m unsure of how much the head weighs.
was told shouldn;t be that much cos its aluminum, mechanic said roughly 30-40kg, so i just got quotes for 50kg just in case for packaging etc, cheapest ones i found are.
air road direct
$116.20 WA, postcode 6000
$93.20 Melb, wasn;t sure of post code so i said 3000 metro area.
prices are for online booking n payment, so that is $22 discountd already
items will be picked up and delivered at given address
however items over 50kg and in metro areas will have extra charge of 24bux for lifting
PhillipsTransport
$120, for Melb. Will need to be picked up from their dispatch centre.
they were charged at flat rate for pallet space i think.
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342959
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
