hey guys, got two heads for sale. 1 DET and 1 DE, both from R33.
***both SOLD***
DET Head:
Comes with inlet manifold, Fuel Rail and injectors, rocker covers, both cams and all sensors seen in pictures. Still assembled on block. Welcome to come n check $450
If u want the whole engine, take it...$550, low compression. Old engine from Swap. pics of engine are dirty cos of spilt oil from mechanics, spilt the tray down the side of it, cleanable.
Has done aprox 115,000km
***SOLD***
DE Head:
Comes with inlet manifold, Fuel Rail and injectors, rocker + coil covers, Loom + ECU, throttle body, coil packs + igniter module, CAS, both cams, extractors. might have missed some things, just check pics or PM for questions.
Only problem is, is that the cams have been removed, becos i was going to use the in cam for current engine, but then i couldn;t be bothered anymore, still included in the package tho, just have to get them put in again. No mechanical faults, did turbo engine conversion. $550
this is also still assembled to block, with all sensors and hoses etc still attached as seen in pictures. so take the whole thing for $650 if u like.
Has done approx. 78,000km
***SOLD***
Pictures here..... click to enlarge.
http://seahorse.strayed.net/misc/RB25Heads.html
Need to get rid of them to make room. so i really can;t be bothered to sell little bits and pieces, unless of cos i have enough people interested, so i can still get rid of the majority.
OK, thanks for reading.
-Henry
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/
would you consider shipping the DE head to WA?
Im not interested in the block, extractors, loom orECU
just everything else with the head including cams and inlet manifold
umm yea will consider, just that still waiting for someone to reply wether he will take de engine or not. get back to you asap.
i;m gettin prices for freight tomorrow for someone in melb.
i'll ask about WA as well. Whats your postcode?
also, anyone know any cheap places? last time i got a pallet of car parts shipped up from victoria, for 70bux...is that any good? if u know a better place, tell me and i'll ask them for price.
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342160
cant really help you on freight prices but I guess $70 for a pallet sounds like a decent deal
as for my poscode is 6000
hmmm ok.
will ask for u anyways, then let u know as soon as i find out about other buyer.
oh. i frogot to mention but, i thoguht it wasn't nessacery...but jsut in case, shipping will be at buyer cost,
sorry if confused anyone
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342162
got some prices for the shipping. its just that i;m unsure of how much the head weighs.
was told shouldn;t be that much cos its aluminum, mechanic said roughly 30-40kg, so i just got quotes for 50kg just in case for packaging etc, cheapest ones i found are.
air road direct
$116.20 WA, postcode 6000
$93.20 Melb, wasn;t sure of post code so i said 3000 metro area.
prices are for online booking n payment, so that is $22 discountd already
items will be picked up and delivered at given address
however items over 50kg and in metro areas will have extra charge of 24bux for lifting
PhillipsTransport
$120, for Melb. Will need to be picked up from their dispatch centre.
they were charged at flat rate for pallet space i think.
https://www.sau.com.au/forums/topic/72916-cheap-rb25-heads/#findComment-1342959
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
