Can anyone help me out here?
Had a bit of a read through here. Was thinking of going Kumho KU31's for my street only 33 gts-t, 270rwhp. Currently got Yokhama advan sports on the back but there about $500+ each and was only looking at spending around $400 mark for each tyre. Only need the rears though for 265/35/18.
mate option1 garage on here sells there KU36, (treadwear rating of 180) for $236 each plus around 15-20bux each for freight.
great tyre, you wont be dissapointed.
kumho ku36
225/45/17 (mounted on a 9 inch wheel)
Dry: 8/10
Wet: 5/10
Value for $$: 10/10.
paid about 160 squid ea, use them as steer tyres, lasted 2 track days and a shit ton of spirited driving so far, got plenty of life left in them yet, and i cant fault them.
dunlop direzza dz 101
235/45/17 (mounted on a 9 inch wheel)
Dry: 8/10
Wet: 8/10
Value for $$: ??/10
got them basically new on my current set of wheels, decided to keep them instead of using what was left in the ku25's i was using before. very predictable tyre, gives you plenty of if its about to give, they warm up quickly, and provide plenty of grip, will definitely use again.
quick update, had a track day yesterday (mallala).
kumho's performed brilliantly once again, offering great throughout the day.
the direzzas however... got a bit unpredictable when i really start leaning on them, and delaminated in chunks and strips, ill post pics later. would use them for street, but not for track.
Atm im running Goodyear eagle F1's cost me 1050 fitted for 2 tyres YES i said 2 for 255 / 35 / 18's :D there awesome in all weather types even when going hard on the pedal. Ive Got Toyo proxes 4s on the front and i notice no handeling problems with 2 different patterns in the wet there good tyres too i would go back to bridgestones if i had the money . I used to run Bridgestone PLAY-Z there old school jap ones which are like a potenza im pretty sure they used to be wicked wicked tyres. :)
as promised.
keep in mind, these were practically brand new when i went out.
That sort of damage is pretty typical of a street tyre that has been used on the track... I have seen it many many times before.
The tyre has heated up to a point where the tread has become too soft and too hot to handle the forces being applied to it and it has lifted tread blocks and "chunked" (technical term :D).
This will happen to just about any street tyre that is used for extended track work because they arent built to withstand the sorts of temps that you generate on the track.
i just found it rather irritating. id previously used ku25's as rear tyres on the track (which are pretty f**kin average tyres imo), and they didnt get anywhere near that bad, and i was pushing just as hard on them.
I also attended the SAU track day.
I was running Toyo Proxxes R888 (275/35R18) all day long. When I found the right tyre pressure (25psi) I had bucket-loads of grip all day long.
When very hot, they obviously provided slightly less grip, but i was really giving them some!
well worth the $512each
I think BIT SUS is on the go, Personally i reckon the r888 would be a great track tyre for its money, I will say one thing tho and its been said a million times dont expect huge things out of street tyres on the track hence there street tyres not track tyres. I was sad to take my Toyo proxes 4's off the rear of mine for everyday use i dont skimp on tyres. Does anybody need any tyres, i have 275's proxes 4's forsale there 98% brand new i took the 2% off because they had a little scrub on the side lol , PM me if ur interested $300 for both.
Freight ?
2 TYRES
SYD METRO
$35
NSW, QLD METRO, VIC, SA METRO
$45
Outer SA & Outer QLD
$70
Metro PERTH & TAS
$100
WA, NT
$120
I picked up a set of Michelin Pilot Sport 3's for the 34 on the weekend and with only limited driving I'm still impressed with them. They have heaps of grip in the dry! I've taken then for a run up Tamborine mountain and they've been a dream. Picked up 4x 235x45x17 for $996.
The test will be how quick they wear...
Quick question guys (didn't want to start another thread)
what do you think would be better for straight line grip (on 18x9" rim, car is soon to be 250rwkw and 99% street driven, not a daily though as i'm a student)
235/40 Pirelli P Zero Rosso
OR
265/35 Kumho KU31
tyre dealer seems to think Pirelli, and i'm inclined to agree. Will the extra 30mm of tread on the Kumhos offset the fact that it's a lower quality tyre?
I just bought my car a few months ago and they came with some tyres called Ling Longs :P funny name eh?
there pretty bad so i'm looking to change to something good, price range is anything from 200 - 400 each, can someone give me some advice on a good tyre
cheers
  • 1 month later...
How do Toyo teo plus compare with the Bridgstone Adrenalin POTENZA on 205 -60- 15.
I cant get much information on Toyo, but what I have got has been pretty positive.
i have used the Adrenalin and got between 30k to 40k for a set of 4. My priority is now changing to having more mileage out of a tyre but with great breaking still a priority ( I guess thats an oxymoron)
Currently have Teoplus on the rear and Michelin Preceda on the front and not happy with the Preceda because of rapid wear rate and handling ( sedate driving and almost worn and only 14000km done. Steering set up was fine) thts
I just changed to Kumho KU36 all round 235/40/18 with 34GTR rims, reason is the width seem almost the same with my previous Falken912 size 245/40/18 which happens to be crap tires after 60% wear. First impression, a lot of grip in the dry and the steering response which used to feel dead has comes alive. This is only my 1st week with it and just try it in the wet...scary when it's cold but once when you warm it up, the grip gets slightly better.
Now i wondering what would the optimum tire pressure front & rear bcos my tyre shop guy recommended 35psi front and 38psi rear. Felt too stiff as a daily ride, and usually every weekend I would go for a blast & twisties with my mates but after midnight.
OR
265/35 Kumho KU31
Go Kumho KU36, I see you are using the same rims as I am. They looks great on the 34GTR rims and offer tremendous grip...sort of Semi-Slick.
Wow I see a lot of 8-9 out of 10 here, and no offence but I think some of you guys need to try even better tyres.....of course the best tyres you've ever used will feel like a 8 or 9 if you haven't compared them to something better :(
My pick of good street tyres are the Falken FK451 at about 450 in 255/40/18. Great tyres wet and dry. The Dunlop SP9000 we are running on the Z at the moment are good too, as they should be at 550ea.
My crap/not worth the money list include Falken 326, Falken ST115 and Bridgestone re040.
My R tyres list goes like this:
Bridgestone Re55 > Dunlop D01J > Yokohama A032R > Falken RS-V04 > Falken RT215
.....but Dunlop DZ02G > *
I must try some slicks so I can add them to the list :(
Did anyone see the tyre test in Motor magazine last month?
Definitely agree with you on Bridgestone RE55 for track!!!
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
