Tyres you use(d) and how u would rate them
Did a trackday with these too, nice for a couple of laps then they get pretty hot and slide around alot.
I would suspect that you might not have had the best pressures in them. Try experimenting with them and you should find that they only get better once warmed up.
I currently have 235/45/17 Michelin Pilot Sport 3's on my 8 inch fronts, and 235/45/17 Adrenalins on my 9 inch rears. (Both around $225ish a tyre when new)
I did a track day on them last year, at that stage they were around 12 & 18 months old respectively.
I got no delamination at all, Michelins help up extremely well for a street tyre. While the Adrenalins spun a bit out of corners, but I'm putting most of that down to my diff.
I'm looking at doing another track day soon. Currently leaning towards Toyo R888's, 235/45/17 for front, and 255/40/17 for the rears.
I've been quoted around $300 per tyre delivered to Melb by Taleb Tyres.
I also have pricing of around $220 & $250 for similar sizes Falken RT615's, but I think I'd prefer a proper semi-slick, than the "street-semi" kinda tyre.
Regarding street use... I'm leaning towards the Michelin Pilot Sport 3's all round, although the 17inch PS3's only go up to 245 at the widest. :(
KUMHO KU21 ECSTA
'All season tyre'
235/40/18 245/40/18 (bit o' stretch)
got recommended to give them a go by my tyre dude as I don't require 2nd gear stand stills/track days every 2 weeks and I'm after a harder compound to last a bit longer.
WET: 6/10
DRY: 6/10
VALUE: 8/10
Pretty quiet ride, they don't warm up much through the hills though (what do you expect) and screech a bit if your hauling ass around twisties.
predictable though, not a bad price. Can't say i like these more than the KU36's i tried previously (handling wise) but fark they were cheaper and will definitely LAST LONGER!
Triangle somethings
Dry 5/10
Wet 0/10
Value 0/10 well i dont wanna die so id say value wise close to 0
They are on a fwd corolla and on the rear tires. Will let go at any speed in the wet. Ridiculously dangerous tires. Tread at 80%.
As far as H/T tyres go:
Achilles Deserthawks H/T 235/50/r18
dry: 7/10
wet: 5/10
value: 9/10
quality: (so far) 9/10
Kumho Solus H/T 215/60/r16
dry: 5/10
wet:3/10
value: 5/10
quality:1/10
Toyo Open Country H/T 215/60/r16
dry: 6/10
wet: 4/10
value: 5/10
quality: 5/10
Using Achilles Deserthawks atm, no complaints. People say they're crappy indo-made tyres, but they are the best H/T tyres I've ever used. Wearing slowly, good grip, fairly cheap, pretty quiet on the street! I know a few guys who have used them on drifters and racers, and they have no complaints either.
Edited by Pork Hunt
Triangle somethings
Dry 5/10
Wet 0/10
I had these on my last 32 was the biggest mistake i ever made the car would let go at any time ESPECIALLY in the wet tread was new and my mate drove the car in the wet ended up in a tree after we aqua planed i got out ok few stiches and scares but my mate is alot worse off has broken near every bone in his body and cant work for the rest of his life.
Please i urge people to never buy these tyres!
Michelin Pilot Precedas 245/40/18
Cost: $450/cnr I think
Lasted 24 months/15,000 kms. No track work.
Street tyre rating
Dry: 8/10
Wet: 7/10
Value: 7/10
Getting Michelin Pilot PS2s 265/35/18s for about same price delivered from Tire-Rack. Should be a step up in terms of dry performance. PS2s seem to be consistently one of, if not THE most highly rated tyre online for dry performance from a street tyre.
sumitomo htr z11 215x40x17 between 200 -250bucks each
dry 9/10
wet 8/10 (excellent anti-aquaplaning)
longevity-awesome
replaced by z111's
firestone firehawk 245x45x17 $200
dry 7,5/10
wet 7/10 (noticeably not as good)
longevity/wear-one year on as daily,awesome
great value street tyre,only 'found out' when really testing them.no good for track.
bridgestone slicks that came with car,awesome on dry,wet, ok.re somethings...o55's?
Edited by GT ARRRGH
  • 1 month later...
Toyo Proxes R1R 265/35x18 ($$ unknown - depends where you buy obviously)
dry 10/10
wet 8/10
longevity-a lot better than i expected
In 2wd w/ 500hp just starts to spin 2nd at high revs.
4wd launching is unbelievable.
Extremely good in the wet, braking and acceleration wise.
Dropped a few skids here and there and expected to cry when i saw them. Barely wearing - very surprised.
Toyo Proxes R1R 265/35x18 ($ unknown - depends where you buy obviously)
dry 10/10
wet 8/10
Thumbs up for proxesthumbsup.gif , best tyres i have ever had .
I've just got 4 x Toyo Proxes T1 Sport (i think this replaced the R1R) 235/45x17.
I'll find out this weekend how they rate at DECA.
Has anyone else used/got these?
dry 9/10
longevity-awesome
replaced by z111's
I've had both Z2 and Z3 on my car, both new 1 day apart. I can tell you the Z3 is a MUCH better tyre than the Z2. And for barely more money, like $30 each. I paid $250 per tyre for the Z3, 235/40/18. If the Pilot Sport 2 was <$300 I'd consider it.
I don't think so?!?! Replacing the T1-S.
T1-Sport is a KU31 like tire (or the KU31 is a T1-S like tire...either way, hankook evo etc etc). So good overall life and grip on the road. Ok for light track days, 2-4 seconds a lap slower than R1-R.
R1-R is a KU36 / 595RSR / AD08 like tire. Fantastic dry grip on the road, standard wet grip on the road. Will wear faster than T1-Sport, but super grippy on the track. Harder sidewalls for better cornering, compound built to last with heat.
Generally lower means softer, means faster on the track, means more wear on the road. so 10-15,000km instead of 15-25,000km.
T1-Sport
UTQG = 240
R1-R
UTQG = 140
T1-Sport
UTQG = 240
R1-R
UTQG = 140
I knew I should've called you before tyre shopping!
  • 1 month later...
Federal 595 SS 235/40/18
Dry 9/10
Wet 7/10
Very good tyres, looses traction well unlike my previous tyres which were unpredictable. Wet grip is very good, was quite surprised.
Not sure if there good enough for the track but I'm gonna give them a go at deca.
Feddys 595SS = 9/10??? You gotta be kidding... I've used them before and they are nothing like what you said, brought it to skid pan, even worse, under heavy braking would lock up in DRY! After warming up, have next to no grip
Kumho KU31 215/40, 235/40
Dry: 7 / 10
Wet: 6 / 10
Value: 8 / 10
Not the best street tyres out there but they provide decent grip when they are new, my car probably have about 180rwkw, however once they wear down to less than 50%, dry and wet grip goes out the window and loses traction very easily
Will try Dunlop Z1 star spec next
Dry: 7 / 10
Wet: 6 / 10
Value: 8 / 10
Just because they lock up doesnt make them crap tyres. Plus on a skid pan there is less grip then the street, I was surprised how crap the grip was at last deca on the skid pan and the wang.
I did brake tests with these tyres and even in semi wet conditions they were really good. There not the evo 595s which are the cheaper ones, maybe you were thinking of them?
I've had ku36's before and on the street there is not much difference between them and the 595 ss, different story for the track but Im scoring them for street use only.
If you consider a ku31 a 7/10 a 595 ss is easy better then a ku31, i had them on my aw11 and they wernt that great.
Hi guys,
how much roughly for a set of Toyo Proxes R1R 275/35x18??
Needing to look at tread pretty soon, car will be doing some track days.
Thanks
    • The autos suck. Anyone with an auto wants to go manual. Also, the one thing you don't really need to change is the dash. You don't really need to know (on the dash) what gear position you have selected. What you do have to change is the tailshaft, a bunch of wiring, probably gearbox crossmember, a bunch of fiddly shit like the spigot bearing in the back end of the crank, find a flex plate and a converter, etc. A whole lot of pain. Most of those autos have been rightfully put into metal recycling bins, so they're not exactly easy to find either.
    • Appreciate it man, gives me hope based on my Google searches on availability of GTR parts.  When you say I'm "not going to," is this in the vein of "who on earth would want auto," or more "it's impossible?" Not trying to be rude, truly don't understand haha. I know, it'd be a madman move to go manny to auto, but if it IS my only option, I'd be curious on the lift.
    • Shit's f**ked. Looks like there might be a crack to the intake valve seat on the opposite side of the chamber also. Defo pull the whole thing down. Nothing good can come from just doing the head on a motor with comp figures that low anyway. You'll hate yourself less in the long run.
    • Well hit the first larger snag in the build!    Car wasn’t running 100% right even before I took it for a drive, starting slow and felt like a bit of a miss so compression tested it once I got it into the garage and on stands for the winter.   That would do it…   Got to tearing everything out and was greeted with this   Seat looks a little mangled but somehow the cylinder is fine   Will check the turbine next wonder if the piece made its way in there and chewed up some fins.    Once I survey the extent of the head damage I’m going to have to make a decision. Cylinder 4 is kind of low anyway so might not be a bad idea to take a peek at the bottom end while I’m already in it
