ku31's or ku39's?
Are the KU39's worth the extra dough?
Im currently running 265-35-18 on the rear. The 255's are much cheaper , would my performance be hurt that much by fitting a 255 in place of the 265's? Car is a daily driver which sees no track use.
May or may not be a help but, the Micra has KU31's on it and they feel good and stick alot better than the Maxxis tyres that were on the stock wheels.
Because of this, I was going to get KU31's for the R33 (my daily) and at $150 / tyre, I thought it was a bargain.
The tread is almost identical to the Dunlop SP Sport Maxx 235/45ZR17 tyres I ended up getting for the same price due to the Managers f**kup. :thumbsup:
I prefer wetwipes lol
Tissues are overrated. My pink pokerdot hanky will do fine :sweat: If the rsr's are half as good as ad08's then that is serious value for money. Mite have to get hold of some & conduct some back to back testing on lakeside. Anyone care to loan me a set for a day?
Yeah i probably shouldnt really be comparing them. Alot happens in tyre technology in 5 years. Mind you kuhmo tyres are fairly decent these days. Good enough to sort of tame a 650hp jza80 (if thats even possible)
You won't feel the difference IMO.
see if you can get an actual chart of tyre widths. The 255 275 etc etc is actually variable. Dont ask me how or why (probably something similar to the rationale to use a combination of metric, imperial and frational notation of tyre size- fail). N think about it, its not like every tyre in every combination is going to be exactly the 265/35/18 fraction. this would also vary. really its an aproximate measurement.
previously i had a 255 tyre on there that was in fact only 245 wide.
my current 275 is full 275...
but all things being equal. no, that kind of difference on the same brand of tyre would be almost impossible to tell by a 'felt' difference
cheers will just go 255's then. i WILL be getting different tyres( swapping the zeix's for ku31's) but for a street only car it should be okay.
what off set and width do you have? im wondering if ill manage to sqeeze 265/35/18's on a 18*9.5 with 30offset on the rear without looking like a 4wd or rubbing when it squats down a bit under WOT. Will be very close i think.
I've been running the Hankook Ventus RS3 for about 6 months now, almost 5000kms.
Been awesome wet or dry, but haven't got them on the track yet.
Wear has been ok, might get 20k or so out of them.
I probably won't buy again unless they make a 245/45r18. The 40 profile puts my speedo out by too much. Unless someone cracks the ECU code and makes it possible to calibrate the speedo.
if you have it lowered and a bit of camber it will be ok. In fact it will look nice and flush. U have rolled or cut the lip out tho right?
I run a 275 on a 18*9.5 +36 with only .5 degree of camber and it is dead flush with the guard. So you will be +6mm further out, less whatever the difference is between that 265 n my 275...
-so basically the same. N u cant get that little camber in a GTST without camber arms. So they will be cambered in further most likely...
  • 4 weeks later...
Michelin Pilot Sport 3 225/35R/17
Dry: 9.5
Wet:9.5
For $245 each they're pricey.In the wet you can flog it on a corner and its amazingly grippy they have this inner tyre tread design you can jump on the brakes and they will stop almost like its dry little to no sliding discovered this when i had to jam my brakes the other day.
FOR dry i would say theyre just as amazing have had bridgestone potenzas but theyre nothing near these tyres you loose little or no traction on silky finish roads.
  • 3 weeks later...
Trying something new!
Achilles ATR Sport 2
putting them on Thursday. Hope they're decent enough for that price. 235/40/18 = 130 .. 255/35/18 = 175 (supplied, fitted and balanced by JaxQuickFitTyres)
I'll update this after I run them in :)
An update :
Got ku31's all round , 235/40/18 & 255/35/18 , $620 all up supplied, balanced & fitted by St George Tyres
D : 9/10
W : 9/10
They are an excellent street tyre , excellent in the dry , excellent in the wet , havnt lost the back end yet. What a night & day difference between the ziex's and the kumho's!
Bang for buck Kumho's are the best out there.
^^ Had the ku31 before i switched to re002, they are good when they are new, once you put some kms on them, it turns to shit, personally i dont find it 9/10 for wet as it breaks traction on 2nd in the wet
Hmm well Ive only put pn about 5000km on the back and 1000km on the front. When do they start getting worse? Ive had numerous reports of them being quite long lasting as well ie 20 000km , its funny that you say that.
I dont break traction at all in the wet(unless im giving it all) but then again I only have 170rwkw so thats not much.
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
