I was the surprised the fronts held up so well, didn't feel like they were going to give up anytime soon
I was driving the car pretty hard as well, didn't really understeer anywhere. It just did what I wanted it to do :)
The nitto invos are a great tyre they put my 336rwkw to the ground nicely :)
Got my Hankook Z222 on the evo yesterday. They are not overly noisey and they didn't make the steering feel as twitchy as it felt with the dunlop SP MAXX that were on it and they did make my steering feel a lil heavier and made turn in a little more progressive.
Havent tested them out in the twisties yet though. Hopefully tonight :)
I gave the RSR's a good run again on the weekend, still not bad for the price! They obviously are cheap tyres but when you drive them at their limit they handle it well! Nice and quiet too...
yh true i have RSR 255/35/18 good in the wet can launch at 3500 with my few killerwasps and it grabs instantly.
This tyre test is interesting. It shows braking from 100km/h dry and wet.
http://www.tyrereviews.co.uk/Article/2012-Autobild-50-Tyre-Braking-Test.htm
Down the bottom there are some real shockers but the mid-range performers seem good value.
I wish i could...
  • Like 1
straight line braking in wet or dry is not a good indicator or lateral grip (corners) nor how they 'feel' or how they grip once traction has been broken and then in regaining traction...
Nonetheless, still meaningful statistics :)
  • 1 month later...
Bridgestone potanzas re240s street slicks
Dry 10/10 once you get heat into them
Wet 3/10 just for normal driving
i rate these types 10/10 for price as im a true believer that you get what you pay for
Edited by rodneytro33
"Potanza RE240s" ? Was wondering what these were. You might want to take another look at your tyre sidewall markings :)
Unless you're referring to the old Potenza RE540s (semi-comps, not slicks), which I believe are long discontinued?
I used Tirerack to get my Michelins due to the fact Michelin Australia cant be bothered bringing 265/35/18 into Australia
Once i sent my money i received my tyres in 5business days too my door!!!
Michelin Australia arnt bringing every size into the country, this is reflected on their website
Re: PSS
Ta Nick for feedback on this :)
*Edit: Much road noise?
  • 2 months later...
Doesn't seem to be a whole lot of posts on here lately.
I have Direzza Sport Z1 Star Spec that i have had on my 33 for the past 18 months or so. I haven't really tried many tyres so i cannot really rate them outta 10 but I am well happy with them. I am glad I spent the $$ and bought some good tyres. Alot better than previous KU31.
I know a few others bought the same tyres from tirerack.com. Any other opinions on these tyres ?
  • 2 months later...
Anyone got a hook up for Hankook RS3?
Want to run a 275 35 18 and RSR dont have that size... (Currently RSR all round but keen to give something else a shot!)
Best price I got was through jax tyres (believe it or not) Prospeed?? I think up the coast go through em a fair bit too give them a try Matt ;)
Yep they are the go! Last set too :)
Hahaha they will blow ya mind mate 1st thing you will notice is all the shit hitting the inside of your guards... Sticky suckers pick up everything u drive over! ;)
Shit... I'll have ripple strips, pedestrians and traffic cones hitting my guards then lolz
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
