4 hours ago, Hadouken said:
Nt01 vs AR1. I would say they are on par.
Was looking for some new fronts for our track car today, and was surprised that in our size (245/40R18) the AR-1's were more expensive than both NT01's & R888R's - by a fair margin. I ordered a pair of the R888R's.
They start making noises and become greasy. But that's when they are so hit pressures are off the gauge. Lol.
Ummm sorry to hear that whoever you got quoted off is trying to rip you. But I paid $240 for 245/45/17 nt01s and I paid $150 for 235/40/17 AR1s
How much where you quote? I paid 205 each fitted for 265/35/18
Cheapest I could find for 245/40R18 AR-1's was $310 each, plus fitting. Other sizes are cheaper, but we want to run the widest tyre we can on our 8" front rims, so that means 245. Bought the same size in R888R for $250 each, and could have had NT01s for a similar price.
Nankang pricing was taken from Sleekaspares in Adelaide (and on Ebay).
Where was this from?
Associated tyre service, Cheltenham, Victoria. I found them and got that price through the tyrecompare.com website. When i called randomly they said 225 but then i pointed out the website price which they honoured.
Thanks - had a look at the tyrecompare website but no pricing listed for the AR-1's in SA.
4 hours ago, ActionDan said:
I got mine here.
Thanks Dan - contacted them today and they want $310 for 245/40R18's.
I know this is a new(ish) size for Au, I was looking earlier this year and could only get 235 in 18's.
There are several different width 18's on ebay that are considerably cheaper - 265/35 for $240 & 225/40 for $224, but 265 won't fit my front rims & 225 is too skinny.
3 hours ago, ActionDan said:
245 is an awkward and expensive size
Only in Nankangs it would seem - have never had issues with Nittos, and now Toyos are readily available & well priced. Not sure about awkward either - 8" is a very common rim width, and 245 is the widest that can (should) go on an 8" rim.
Only minor PB improvement which was disappointing as they are wider and supposedly sticker. This is compared to 6yr old thrased 235 RS-R.
However, first session was wet, car had misfire, second session was dry and i shaved off some tenths on the PB without thinking I was going that fast, 3rd session I made a camber/damper adjustment which felt probably better in some ways, worse in others, but got held up in traffic on each hot lap then busted the car (minor).
There's definitely more in it, but I was not immediately blown away.
I also think I made the mistake of running too low hot pressures, around 34ish. They also seem like to firmer damper settings.
Can see the driver side cops it worse at this track, anti-clockwise with a highish speed continuous right hander.
I feel like I could have done the same thing on 255 RS-RR, which will last longer and cost less.
It was also a hotter day than my last PB, despite rain it was still 30 degrees.
Wont get another go til next year and by then will have made other changes to the car. Will aim for higher hot temps.
Dirt on the outside is from driving onto grass to load car.
Edited by ActionDan
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
