  jmac said:
Side point Harry - Lakeside is open???!?? :)
sort of... Total Driver managed to get permission to include sprints in one of their training days. It was awesome to get back out on that track!
Pine RIvers Shire Council is due to make their decision on the tender process for the management of Lakeside any day now, and their target is to have the place open by September, so stay tuned!
I can't believe its happening! :)
I've got
235/40Z/R17 and 255/40Z/R17 yokohama AVS 102's all round. Directional tyre, work well. Grip is good. $330 and $360 fitted each.
PS I've just been informed that they are no longer available!!! Damn!!!
  tridentt150v said:
I've got
They are available, however it is a long wait. I have been waiting for the Yoko V103's for almost 9-10 weeks. Now they have advised the shipment is still in Japan and that there is a further wait of 6-8 weeks.
I couldn't wait that long as my tyres were getting very slim, so I found a set of brand new Dunlop SP3000A (OEM tyre on the XR6, XR8 and XR6 Turbo) on EBAY ( Thanks Jason). Paid $600 for all four. Not a bad price.
Performance so far is great. Looking forward to a spirited mountain run to give them a real test.
Dry = 8.5
Wet = 8 (haven't really pushed too hard yet as the tyres are too new.)
  evil_weevil said:
getting the yoko C drives on monday - will let you all know how they go after a few drives compared to my 3000A's
:P
Cool cool. Make sure you give them atleast a few hundred km to a thousand km to wear in a little before you start giving them some grief!! lol :P
Just bought a set of Falken FK 452's. 2x 235/45/17 and 2 x 255/40/17's
They are very good. Together with a good wheel alignment my car feels toatally different to drive. Excellent grip considering my diff is worn. Had ZE-326's before these and my car was constantly single wheeling on power and now it takes much more to get it spinning the wheels.
Can't comment on the wet yet.
This is on a lightly modded R33 gtst by the way.
Got a set of Federal SS595 245x50x16 on all fours. Wont be able to test them until the engine's in, early week after next. Wll be pushin 400awkw's, should be interesting to see how the handle.
BTW i paid $145.90ea
Just installed Toyo T1R for my rear 245/40/45 (fronts installed 2 month ago), first think i notice after getting out of the shop is the quietness in the cabin & road noise. Once i hit the highways, the ride was really smooth and quiet, the only audible noise is coming from my open pod air filter. The slight increase of sidewall thickness is more comfortable on bumpy surface.
Haven't tried on wet yet, gotta run it in a little more. Keep everyone posted.
I think you will find any tyre in a semi-silica or a full silica, will be quiet on the road. but good to know, i do a heap of long drives to country vic from adelaide, and i would like to know what tyres are quiet.
depends on the size of the tread blocks, large square-on tread blocks are noisy while blocks that are tapered and smaller are less noisy.
silica definitely helps wet grip and longetivity, it might help noise as well!
Bridgestone SO3. 255/17 rear and 235/17 front.
Approx 450-490 per corner.
I have run bridgestones right back since the SO1's thru to SO2's.
I run the full Whiteline Suspension Works Pack and its a brilliant combo.
They last me two years per set, driven hard and daily, never failed.
I Rotate them evry 6 months.
I also run them on my stock R33 Sedan.
Brilliant
Car handling felt good and the quietness is still there...probably done 2000kms by now. Recently i pump up the pressure from 32psi allround to 34psi front & 32psi rear, the car handles pretty weird on long sweeping corners. The front twitch a little then rear felt like it's gonna give way. No sure whether the car was gonna understeer before i counter it slightly but the experienced gave me quite a shock though.
btw im running 235/40/18 front & 245/40/18 rear and still on standard shock/springs. What tyre pressure are u guys running for this sort of setup?
hey mate
i have run 255/40/17 t1-r on the rear for a while now and i have found that they have soft sidewalls (relative to other low profile tyres i have tried) so to get them best out of them i aways run them at minimum 38psi, they feel the best at about 42. when u pump them to 42 they get a LOT sharper than when they are mid 30's.
i agree they are one of the quietest tyre in that size and profile, i use dunlop sp sport maxx on the front and they are way noisier than t1-rs even when brand new compared to old t1-rs.
the sidewall flex can be unnerving especially in conjunction with stupid hicas, but they start sliding gradually so you learn to trust them.
Morning fellas,
i run 42-45psi n my SO3's , anything less than that and it can get a bit slippery!
I have adjustable whiteline swaybars, the are set on the 1st of the four settings, shes pretty ruf arond town but its brilliant at higherspeeds.
i make a regular night trip reasonable quickly from pakenham to healesville and its a bad road but the setup never fails, the car satys solid.
I have spent more $$$ building the suspension brakes and tyres than the engine.
This is the best i can find, whitline all the way.
come to think of it i hav never tried the 4th setting.
:rofl:
Thanks Siks & Ronin
I took the car for a drive on some sweeping canyon uphill & downhill on the weekend with 32PSI all round, the tyre really do slide a little (soft sidewall). Then i felt when down left hander turns, heard some noice & knocking sound probably from my shocks. Maybe its time to change them, not sure how long since i bought the car had original shock on.
Will try to pump up the tyre tomoro to whether the ride & handling be better. Should it be pump up equally on all tyres or just the back? Is the car gonna have oversteer just increasing the rear?
Have'nt driven the GTR for a while now as the Steel belts are hanging out on the rear, so finally rang around a few tyre places today.
I like the idea of Federals 595 range, but still unsure which way to go for my car which probably will see 5000kms per year including maybe 4 competitive track events.
595-ss Treadwear 240
245/40/18 = $255 ($1020)
265/35/18 = $320 ($1280)
595-rs Treadwear 180
265/35/18 = $470 ($1880)
I have approval from the Mrs to go for the 595-rs's, after some....urm...discussion! :) and they would look horn, but are they worth it for a handfull of competive events, or would the 595-ss's be 90% as good for 50% of the money?
What do you guys reckon...?
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
