The RS-R run slightly wide as well. Go the same size you did on those.
Will see how i go... A few supply issues with them as they are discontinued!
I didn't notice my RS3's to be any wider than the dunlops that were on the evo.. The federals have a massive casing too so you shouldn't have a drama with the hankooks fitting under your car Matt :yes:
Good because there are no more 265s available so 275 it is lol
Well you will be at 1 with traction now son :D
Oh i dont know about that :whistling:
But the car is booked in with Road2Race to get it setup right :yes:
I've had kumho ku36 in 265/35/18 all around on my gtr for about a year and half now
In the beginning they were good, now for past year they are just getting harder and harder and the tyre noise is unbearable, drives me crazy !
Rears have about 20-30% left fronts about 40%
I'm taking them off and going for nitto INVO's in 265 have herd nothing but good things about them
The invo's are a great tyre Michael had em on my old 33 they are literally silent on the road and I found them really good in the wet too! ;)
When are these RS3's going on Matty? :)
2 are on, 2 are for sale...
Road test this weekend :banana:
Got some 235 Z222s on the front and some 255 Fed RSR on the back
Will let you know how they go at racewars :) ( if my cars ready )
You are all backwards :P
I have 255RSR up the front and 275 Z222 down the back ;)
Was going to get Rsr all around,
Could get front z222 cheaper than rsr, so i got them.
I do track work, so tighter tyres on front could be better
Yeah i will be doing plenty of track work and know the RSR front wont be up to the task ;)
I have just scored a set of 34GTR rims and will start researching proper tyres and will keep the current combo as my street/thrasher set!
Make sure you report back with thoughts on the Z222 ;)
This is 275 grip on the rear :P
1265536_700169503374776_1002666072_o_zps
I have 245/40s on my 34 GTR runs (on a 33 gtst s2) and they seem OK. Looking for a replacement and thinking RE050A or Pirelli?? Or the Invo's you guys all seem to rate. My RE01s are worn and the road noise is terrible, looking for a grippy but quiet set.
I just scored a set of 34GTR rims and will run Hankook z221 all round in 265/35/18... Not ideal for street though! Ill run the XT7 setup for street!
The RSR's kept me on the runway at 240km/h at racewars, thats a pass for me :)
Will let you know how they go on the track.
Pressures make the biggest difference with the RSR!
Ill have mine on the track on the 25th too :yes:
  • 3 weeks later...
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
