ive got fed 595 ss in a 185 50 14. they just are not grippy enough. great round the corners, but shit. the car is light. its only 170kw, i cannot get traction.
I have the FED 595's on my Skyline
255/35/18 - Rear
225/35/18 - Front
They are pretty good wet and dry......but then I came from Falken's, so anything is better these days. I miss the 90's when Falken wasn't pretty much a retread company! They kept my RX2 on the road at 200+ KPH back in 96!
255/35/18 - Rear
225/35/18 - Front
maybe im not getting enough heat into them to activate the rubber...... oh well. see how we go.
Just did a track day at lake side in my 34 Gtt
Had federal 595 supersteel tyres fitted all round
225/40/17
The track was wet alot of the day and the federals were absolutely ridiculously insanely rubbish!
I got about 3 laps in when there was a dry racing line and they were still horrible.
Wet traction 1/10
Dry traction 4/10
V/f/m : 5/10
They're not a track day tyre. They are not that good in the rain, then I had them, I had to warm them up in the wet on the roads (very annoying). There are better tyres out there for the price (e.g. KU31).
I know they were just fitted to the car when i picked it up. Only had it for 3 days didnt get a chance to get another set of rims and put some semi's on them.
100 bucks a tyre for my little micra. they are decent. however im hoping for more from them when it warms up abit....
i would have gone for ku31s tho, but i cant get them in 184 55 14 in melbourne!
Nitto NT-01
Treadwear 100
255/40/17 at $240 per side fitted (Week 48, 2013)
Dry: 9/10
Wet : N/A - have not tested
Value for $: 7/10
Installed these on the rear of my shit box, normally when I stomp on the accelerator in 2nd tyres will spin and car would just smash the rev limiter I run soft rear springs with a 2-way KAAZ diff, but with the Nitto NT-01 the car would just bite and rocket forward without the slightest hint of wheel spin.
With the Nitto INVO and Federal RS-R, the car would move nowhere just spin tyres and smash the limiter.
With the Nitto NT-01, it's transformed the traction issue into nothing.
Nitto NT-01
Treadwear 100
Dry: 9/10
Value for $: 7/10
Installed these on the rear of my shit box, normally when I stomp on the accelerator in 2nd tyres will spin and car would just smash the rev limiter I run soft rear springs with a 2-way KAAZ diff, but with the Nitto NT-01 the car would just bite and rocket forward and destroy the gearbox...
Fixed ;) It is what happened when i finally got grip anyway lol
  • Like 1
hahahhaha I must say, when I shift really hard into gear all I get is this massive THUD... I feel sorry for the entire drive train LOL
Oh that is asking for failure! Post pics after the big bang :P
I'm buying a set of tyres for daily use + I will use them for fun driving until I buy a set of semi slicks
Tossing up between Toyo Proxes T1 Sport or Michelin Pilot Sport 3 in 235/45r17
Toyo = $620/set fitted
Michelin = $628/set fitted
Call it same price. What to choose?!
Toyo
Michelin
Recently got a set of Yokohama AD08R 235/40 on my R33. The car will be used mainly on track but occasionally on the orad also which is why I opted for them before getting R Compe tires. So far, on the road, they are quite grippy and not very noisy. Will update once I take it to the track
Amir
