Thanks for feedback. How were the INVO's noise wise? I'm considering Michelin MC5 for my wagon as they are apparently quite.
very quiet.. very very quiet.. I dare say more quiet than the RE003 on the daily corolla.. but then again it's a corolla vs the r33.. the r33 has more sound deadening
ok after a drive in the mountains today I'm quite happy with the RE003's, with the tyre pressure now at 42psi (235/45/71 size). Didn't seem to overheat, gripped well and fairly progressive with the loss of traction. Not bad for cheap tyres.
RE003 is a street tyre. AD08R is a crossover track day tyre.
Understand that, just wondering if you were spending $200 for a street tyre which one would you buy . Probably get more Klms out of the RE003s
The AD08Rs seem a great all rounder, not sure how they will be once they are loosing some tread in the wet ??
ad08r are terrible in the wet, they are an extreme performance summer tyre so no surprise there
If you need traction in the wet, you need to find those with big water channels in the tread design (eagle F1, re003 comes to mind)
If you are not after out right grip, then go for re003s, but if you go to the track and want max grip, then ad08r/rs3s are the solution
  • Like 1
You haven't stated what your intended use is. AD08 for track days, RE003 for street driving. RE003 will last longer and have better wet grip. AD08 is one of the best dry grip street legal tyre you can buy. They're okay in the wet, better than what the tread pattern hints (on a WRX STi anyway), just take it easy.
At this time I just drive around country roads with plenty of fun sections.
I know reading and watching vids does not always tell the story, but it is better than nothing and was all I had to go off. It is hard getting past the manufacturers input ?
A lot of what I read before I bought them sort of backs up what you blokes have said about the wet, but I do not think they are that bad in the wet, BUT there is wet and there is WET! I think you are mainly talking about track work. I saw a couple of vids with these in the wet but they were from drivers not pushing it and a little weak on the KWs.
The best thing is, when it is raining that hard, I slow down a bit as there are too many dry days to enjoy.
But these tyres are great fun in the dry, like s**t to a blanket and unless you are smashing it , not bad in the wet :)
Which tyres? AD08R?
A mate of mine change the tyres on his then MY05 STi from the stock RE7-whatever to AD08 and said it was an improvement (softer sidewalls, heated up quicker, slightly better wet grip because it heated quicker). Was his daily until he sold it for an overseas trip.
after driving the mountain again today, as well as it being still damp in some sections, I further recommend the re003's. No issues with them at all today, very good in cornering, braking, wet weather. And this is impartial as I was prepared to not rate them at all in the initial 300k's. Will be interested now to see if there's much performance drop-off as they wear and what sort of life I will get out of them.
  • Like 1
can anyone recommend some budget friendly but decent tyres, rears around 245 - 255 (could go slightly bigger) for use on hill climbs. track only car
Needs to be grippy, 99% of the time in the dry so can afford shit wet weather tyres.
noise who cares
wear not to important either
track in generally slightly dusty
noise who cares
Rs3
noise who cares
Rs3
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine and drivetrain will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe, give me my power goals I want and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
