On 5/18/2017 at 1:31 PM, Adz2332 said:
have a mate who can get them
On 5/18/2017 at 3:01 PM, Adz2332 said:
... and yes name cant be said :P
13 minutes ago, ActionDan said:
Then how the hell did you he get them for $130 lol
Different class of tyre. Dual purpose tyre vs r spec Motorsport tyre. Got to compare apples with apples. Theoretically the AR1 should be much quicker but there hasn't been many reviews where people can actually compare them to a decent r spec and say I went this much quicker or slower with everything else being equal. I am going to get a set when my current a050 are finished and compare times. Got an event or 2 left in them so still a while away. I can get 265 18's for 205 fitted here. Why don't you get a set Dan and tell us how they stack up against your shagged rsr[emoji6]
  • Like 1
I'm fully aware they are different class rubber.
My point being that if I go 1sec faster on 255 rs-rr and say 2sec faster on AR1, the AR1 are better value dollar for speed.
All that said, this is still budget racing so I want them to last while giving me some thrills.l and not breaking the bank.
Oh and going AR1 will likely bump me out of the class I'm most competitive in, I'll be in with the big hp, full slick, serious cars, so no chance of finishing near the top.
That's not that important in the end, but winning is always nice too.
I'll leaning that way, but in the middle of sussing out a new helmet and Hans also.
If you guys are already committed and only a month or two away, I can wait.
It's gonna be wet here for at least another month and I have some projects I want to finish on the car before I take it out again anyway.
Hadouken comparing to RS3 I think so both reviews will be good.
In a month or two I will be getting a set.
Then should at least give it some comparison to entry level r comps.
Nothing will ever compare to a050s lol. They were amazing.
If I can get within a second of them I'll be happy. Thing was with the a050 I didn't have my car set up right the first couple of track days, so I didn't get the most out of them. Also as my driving gets better with seat time, I'm hoping to possibly even match the times. I guess what I'm saying is, I didn't get the full potential out of the a050 so the AR1 should have a chance of getting close.
Edit. Full slicks > a050
  • Like 1
May be a few months for me, depending if I can get 1 or 2 more days out of these. 1 of them is looking a little sad. I'll see what that looks like after the next outing. I'm committed unless I find a050 for 200 a piece again. Very very unlikely, lol.
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
