Hi All,
I'm having real trouble completing the Driving Mission #23 in GT4.
It's the slipstreaming one using R34 GTRs. One is miles in front while the others hang around in a pack. I've tried dragging the pack along for three laps but never get within 3 secs. I've also tried ditching the pack and going it alone but my best is 2.7 secs behind the leader. Any suggestions?
I need this to win the Pagini Zonda.
https://www.sau.com.au/forums/topic/72955-gt4-driving-mission-23/
What worked for me was at the start you slipstream them all and get in front. When in front, stay on the same racing line that they take. It will take them a while to catch up, and then just let them pass you and keep slipstreaming and passing etc... Then the last corner you get a good slipstream and past the pack and you should be able to get onto the back of the first skyline and pass him.
I tried everything else at first and then tried that and first time I did, I won :headspin:
Was at it again last night and just took the red GTR out of the pack and tried slipstreaming this car alone. The others hung back slightly behind us.
I got closer, 1.7secs behind, but still no cigar, no Zonda, and no happy, happy, joy, joy dance. :D
  • 3 weeks later...
yea, yea that is a tough one...I tried a few different things, but nothing worked. I picked a car and just pushed it around the track, I tried to make the other cars get in my slip-stream and boost ahead, I tried driving after the leader....all no good :D
I only got within 4secs of the lead car...
Glad to hear I'm not the only one having trouble with this one !! It's been driving me around the bend :hellpisd: ( no pun intended ).
The best I was able to do was 1.14 sec off the lead car by slip-streaming the pack & sling shotting past at max speed and then running the inner line of the track as smooth as possible until the very last bend & trying to slip-stream the lead car. But as yet ( after about 30 tries ) no joy :)
I don't get it. I slip-stream them from the start and sling shot past them, I then stay on the race line but they never catch up to me. When they start getting close it's usually leading into one of the corners and then the poofs back off !! It's really starting to pi$$ me off.
I really think they should have a road rage version of GT4 where ( in this case ) you can run the other Skylines in the pack off the road if they don't drive fast enough and then drag the driver out of the car and stomp on his / her head until you feel better. Or just combine GT4 with GTA San Andres and while you're racing you can mow the mo-fo down with a hail o 9mm's. :rofl:
Thanks for the help. I got it :jump: and then nailed every other mission right after up to the last one where you have to drive that piece of crap, lounge chair merc around N/B/Ring. Still working on that one.
I still think the mission was crap cause who really comes belting into a corner and stabs the brake's ???? For that matter, why would anyone in an R34 GT-R lift off the loud pedal ??? Or anyone in a Skyline for that matter ??? :D
Yay!! I did it about an hour ago, here's some pointers. They work, trust me:
1 - NEVER try to go too fast past the other cars, keep it to about 275kph when you go past them, this will mean you will still give them your slipstream, meaning they can then get back past you & you pass them again, repeat repeat etc etc.
2 - The third yellow line (the one you start on), try to keep your right hand wheels on this for as much of the course as you can, as this is the main line & it will keep them behind you as much as possible.
3 - Most of the time the AI won't move to overtake you, so if you are going straight look behind you & move out of the way as late as possible to give them a higher speed. Usually move to the right, because they usually prefer the left.
4 - Early on, or even at all, avoid colliding with the other cars because they seem to take it personally (against each other too), and will ram you back, slowing the whole thing down.
5 - I won by 2.8s trying these tactics first shot, I had always kept the same line, but never a lower speed.
6 - Don't get angry that you only get 10k for winning, when most of you have probably spent a couple of hours trying to get this one done. ;)
I still think the mission was crap cause who really comes belting into a corner and stabs the brake's ???? For that matter, why would anyone in an R34 GT-R lift off the loud pedal ??? Or anyone in a Skyline for that matter ??? :rofl:
Dude when you finish the NB RING can you come and do it for me???? :confused:
This track is giving me the sh*ts!
My controller almost went through the TV the other day!!!!!
  • 3 weeks later...
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
