R32 GTR 89 w/ FORGED PISTONS
Metallic red
56000 kms
Big bore 2.72 ltr HKS kit with forged piston
N1 turbos 0.60 Comp, 0.64 Rear (not fitted to car)
Standard turbos fitted
2 chips in the ecu (switchable)
3.5 inch exhaust
2.5 inch front pipes
Twin plate clutch
Hicas lock bar
HKS pod filters
Height adjustable suspension
Tein castor rods
Cusco front upper links
Cusco adjustable rear upper arms
Cusco front and rear strut braces
3 piece rims 17 by 9 with 255 tyres
Large rear wing
Original undamaged front bar and lip
Slotted front rotors
A/M brake pads
Alpine head unit
Sony 4 way amp
Alpine splits in front
Bose rear speakers
Nismo 320kmh Speedo
Defi boost gauge
I can do the car for $20500 minus the boost gauge, upper links, N1 turbos and engineering($1000).
Or $23500 for the lot engineered
Possibly could do it $1250 cheaper on both prices if I swapped the engine for the other RB26 I have.
Now I'm off apprentice wages and moved back home I'm going to spend a lot more and buy a highly worked gtr.
Please call if your serious
0417 370 869
Gareth
https://www.sau.com.au/forums/topic/72995-r32-gtr-89-w-forged-pistons-in-vic/
No offence but if i remember correctly this GTR needed to have the engine fixed as it was on its way out?
If this isn't the car then i appologise...
Just that i remember it on J-Spec or Imports101 i think it was
I can personally vouch for the fact the engine runs, and runs well, nothing needs fixing on it from what i could tell.
Rowdy's a good bloke, and well in to the Skyline Club in Melb, he's not about to go stooging someone over this sale and giving himself a bad name.
Hi are you willing to do a compression test or leak down test for us interstate before we look into this seriously?
its a good price for a car here in aust.
thanks
Ther is nothing wrong with the engine, there was another gtr for salew that was red with a shagged engine. I haven't had a chance to even look at the car since I bought it but I should be able to do a comp test this w/e.
hi mate,
yes i beleive you , but for peace of mind as i would with any car, before i ring you and arrange a flight from brisbane to melbourne its nice to know compression on the cylinders.
as i'd do one before i handed over the cash anyway.
thanks v much.
ps - any more pics would be grately appreciated? ie here in aust.
thanks
Hi,
Thanks to your inability to please a potential buyer (all i ask is that you done a compression test) Ive took my 30k elsewhere and purchased another GTR.
I liked the look of this car and we would have done the deal by now if i knew it was all sweet. I had the money and wanted a GTR now.
On your Behalf, if you want to sell a car it doesnt take much effort at all to do a compression test.
For this reason, until i have proof otherwise, i beleive in my mind the car has a problem... you must understand that logic.
I was waiting for communication to say the car was good, i would of booked a flight, checked the car and possibly bought it.
thanks for your help, or lack of it.
Good Luck selling the car. It looks a beast.
Michael
If you were keen you would have called me. Reed the add! Stop talking s**t you are obviously just another time waster! I know the car is fine and I could have tested if if I knew you were really serious. I could have said that it was fine and all you could do was believe me but at least I'm not a liar. I have only just finished changing the turbos to the n1's over the last few night (wasn't at home on the weekend) so at least i know they're good and the car goes fairly hard with them on only 12psi. Next will be changing the spark plugs and change all the oils so I will comp test it then and then put it on the dyno. Just to let you know there was no blow by oil in the inlet pipes and the car doesn't blow any smoke and it pulls very hard down low and boosts early so I would assume that it has very good comp.
hey mate if your interested in doin a swap on a 95 180sx with 230 kw atw and run a 12.5 quater let me know if spent about 20 k on my 180 so its pretty full on if not hope u still got this car when i sell mine
cheers anthony
u can email me at [email protected]
Gareth can you email me some more pics at [email protected] Depending how the sale is going id be interested in having a look when i get back to Melb at the end of the month.
As for trade ppl, he also has an R32 GTST with an RB26, so dont know how keen he will be:(
Ppl i have personally found Gareth to be a honest and helpful person, as such i have full confidence that he is doing his best to keep you informed.
That is one wicked looking car; if that's not modified enough what is? :D
More pics would be great ;)
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
