Hi !
Could anyone tell me what turbo this is.
I bought it as a R34 N1 turbo though not sure if it is or not.
I have done a HEAP of searching and have found that 34 N1 turbos should have :
0.60 front
0.64 rear
9 blade rear wheel
No markings on the front compressor housing
These turbos have:
0.42 front
0.64 rear
9 blade rear wheel
No markings on front housing
Does this turbo look like an R34 N1 ?
There is no plaque
On the rear it has written:
0.64 428-2 TR7093
Any help appreciated !!! :thumbsup:
https://www.sau.com.au/forums/topic/73007-help-r34-n1/
Ok I will let you know these turbos are R34 N1 turbine because of the following:
1. it has no markings on front compressor while nismo turbos do ie a/r .60
2. it has nine blades at the back while r32 nismo turbs have 12
3. if it spins really, really, really easily than that means its a ball bearing turbo, while r32 nismo turbos are not.
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343533
Yeah those three points are valid
BUT
It has a compressor A/R of 0.42 instead of the 0.60 A/r
Apparently all R34 N1 turbos have a compressor A/R of 0.60
The A/R I can see written inside the "tube" part of the compressor housing (sorry not sure of the name of that particular bit of the turbo but where the compressed air goes out of the turbo and off to the intercooler).
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343625
OK guys
I ?think? I have similar turbos currently fitted to my R32 GTR (only just)
Part Number is : 14411-AA403 (both turbos did have the plaque)
Which according to Nissan are series 3 R34 N1s – with SS internals and BB rollers. They also have 9 blades
BUT
Mine also have a small separator between the rear turbine wheel and the waste gate (which yours do not seem to have – tho the picture is a little fizzy)
I have only just had them fitted and have not had the chance to fire them up yet, so I can't tell you how they will go. I'm waiting for PCF + EBC to be fitted in a week or so.
I'm also fairly sure they are .42 A/R on the comp side (can't be sure and the pics I have do not show it) and they came off an R34 V-spec II AFAIK
I do have a SQ (silly question) Are Nismo and N1 the SAME thing?
My understanding is that there are N1 turbos and Nismo turbos – and only the Nismo turbos have the .60 compressor housing - but I could be making it all up :cheers:
HtH
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343650
Indeed they are the specs of the 34N1s that UAS are selling
A search of the forum will reveal that there are many types of 34N1, and I have now found that they came out in a 0.42 compressor as well as a 0.60 A/R
Pete you got the ones with the 0.60 compressor which are the ones I was after, so I'm selling these and will try and get some with the larger compressor housing. Either that or I'm also working on the possibility of swapping the comp covers over to the larger housing.
EDIT: have found a pair of 0.60 A/R covers so will see if these fit once they arrive. in the meantime have taken off the market. if they dont fit i'll have to put them up for sale again. here's hoping!! :(
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344187
yeah no worry ,i lose track of whos who no here sometimes, i have got a another guy down this way chasing the r34n1 aswell
i'm concidering see if there any interest in group buy
as i was talking to turbotec yesterday and
there off the street price is ~$2325ea
if we get a group buy going ~$2000ea
not bad for such a great turbo(the turbos that won targa this year i believe)
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344473
Flicking through an old mag and they made mention of N1 turbos and NISMO Group A turbos. Both available through Nissan apparently.
Saying the N1s were same size as standard with better flow capabilities obviously and that the Group A turbos were identified by there larger 0.6 compressor housing. Maybe this is the confusion or group A turbos are something different again?
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344537
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
