Well its come time to sell my 33. I have to sell to make way for a home loan. I've had this car since it landed in Aus 2 and a half years ago. The car has been serviced by PVP imports every 5,000km's (basic oil/oil filter change). I've only just put these together from memory and if theres anything missing i will add asap.
1993 Series 1 R33 GTST
Burgandy
110,000 km's
5 speed man
ENGINE
-Turbosmart dual stage boost controller
-Apexi power intake filter
-Apexi bar and plate intercooler
-Apexi dual chamber BOV (have a stock one if preferred)
-Bosch 910 fuel pump
-3 and half inche exhaust turbo back
-Apexi power FC
DRIVELINE/SUSPENSION
-Lowered front and rear suspension
-Front shockers are dampening adjustable
-Xtreme heavy duty clutch
-Shimmed diff
-Front strut brace
-Pineapples
-Gearbox mount
INTERIOR
-Autometer boost gauge
-Apexi RSM meter
-New handbrake and gear boots
-Nismo gear knob
-Pioneer CD player 7*** series
-6 inche kicker speakers rear
-6 inche kicker splits front
-Full alarm system (is a pager alarm system but i have mislocated my pager :S )
EXTERIOR
-stock wheels powder coated white
-Stock Mspec kit
ASKING PRICE - $20,000 ONO
NOW.... i also have extras that havent been put on the car. This includes
-STR cam gear
-OS Giken twin plate and flywheel (USED)
If these parts are wanted with the car something can be arranged but if not i'll just sell them seperatly.
If there are any questions at all or after any pictures PM me or email me at [email protected]
https://www.sau.com.au/forums/topic/73045-r33-gtst-for-sale/
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
