I can recommend a GREAT Fiat, Lancia and Lada workshop in Market St :)
But for an S15: Chasers is close by - in West Melb.
They are on Dynon Rd now. Head around past Telstra Dome - 10mins away.
From their website: http://www.chasers.com.au
ph. 0433 184724 or 0438 668880
Unit 4, 440 Dynon Road
West Melbourne
Yeah call Chasers for sure. Their new shop is 440 Dynon road which is the contination of Spencer Street. Dyno went in yesterday. Call Benny on his new number 0416009785.
Tell him Jevan from the Skyline forum sent you down and he will look after you!! Check out the Silver R34 GTR that is in the shop at the moment!! AMAZING
Hehe - maybe. But from the little I know about the car and it's future intensions it's a "go in a straight line" project. And from what I hear it's planned to be a monster. I'm looking forwards to seeing the project finished.
So in another twisty competition it still may get owned no matter what is done to it. Especially if like the last time it tries to do circuit work on Nitto's LOL.
Chances are if the last DVD was a 1/4 mile comp I would have finished 3rd - not 1st anyways. So it's horses for coarses. I was actually a little suprised with the cars that turned out truth to be told. It was a track challenge and other than my car the Hypertech S15 was the only other car actually set-up for track. The others were either drag or drift cars.
I have been talking to Simon about Serious Performance 9 DVD and doing a top speed challenge. In that the Silver GTR would probably own me - but I think the Ice Supra would have us both. LOL
I want Luffs job, tour around punting other ppl cars:( Luff Snr thrashed the beejeezus out of my old dear in front of the Serious Performance cameras and the footage never saw the light of day:( Goes to show other then me noone is interested in little 32GTSTs:)
When i drop my car off Troy i would like some rockets pls, just as long as they dont stuff up the paintwork...picking bonnet up this weekend, will call you next week when i know when ill be back in Melb:)
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle oven it :(
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle over it :(
In the middle of building a new bake oven at the moment....you might get the first job to roll out of it...you know the one where you bust a full champers bottle over it :cheers:
No way man! You can *accidentally* install Troy's carbon bonnet on my thing if you want to :)
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
