just before I sold my 33gtr I had a run with a 6l ls2 off the lights and I had him by several car lengths (4-5) towards the top of third. off a rolling start it was close, i was only walking away from him. my car at the time was stock except had boost restrictor removed and it had run 12.8 at calder.
So I think out on the streets if a stock gtr launches it will beat a stock LS2 comfortably, and should be line ball with a 185-200rwkw gtst.
  • Replies 321
A mates mate the other day had a SS with some work done to it and was paying out jap cars etc.. i turned around and said whenever you want to line up let me know, he knew i'd kill him, so turned around and said 'sure lets see how youd go towing 2 tonne trailor and 5 people' my comment was 'are we racing or are we taking the kids and caravan on a holiday'
tell him that the old magna-doodle won wheels towing car of the year last year ...that will fix him up :D
Here's a in car footage of my car doing a 0-100km/h sprint.
http://users.tpg.com.au/mcurro/clips/5.4_seconds.WMV
Shit that launches good!!
I seen a big sign on the motorway the other day advertising the 6 Litre. I was like "wtf that's more than 2x RB25 engines, where am I gonna put the 2nd 1" haha.
Can't beat the V8 rumble. I much prefer it to a spooling turbo. Also can't help to think you could shift quicker between 1st to 2nd??
GTRs would cream you.
Until on the 10th run the GTR's stock clutch drops its guts and you cruise off!!
But then - a nice big twin or triple plate clutch goes in + a massive weight reduction from the drivers hip pocket and it is back in business.
sorry to tell you dude but if you were in sydney and pulled up next to me on the lights i would bring your 297kw machine to shame, unfortunatly i love the 6l commo's and am considering buying one so lets decide now never to race off the rights so i dont change my mind in buying one.
I concede that a stock GTR be it r32,33, or 34 will have me in a drag. The only way I would win is if the other driver didn't know how to drive well or if he bought a lemon which was not tuned well. I'm sure there must be a few out there that aren't what they used to be.
As for the GTST's, from what you guys have told me a good match would be one that is modded with more than 185rwkw.
4-5 car lengths up to 3rd gear is pretty huge. I would believe that there would only be 1 or 2 car lengths within it. How do you know he didn't brake as the speeds were getting ridiculous and that he admitted defeat after seeing that you were already ahead?
To show you what I mean. Here is a clip of a LS2 taking on a modded twin turbo supra. The supra was about 1/2-1 car length ahead at the 150km/h or so before the ls2 stopped. Supra kept going and when he hit the brakes, was about 6 car lengths in front.
http://users.tpg.com.au/mcurro/clips/TwinT...praVShsvLS2.WMV
The GTR probably does 0-100 in around 4 flat... so over 1sec quicker than your car...
at 100ks/h how many car lengths is in 1 second? :P
100 km/h = 27.7777778 meters / second
But top of 3rd in a GTR is around 180.
I didn't release a stock GTR runs 4 second flat 0-100km/h even with the restrictor off. I thought that it would be more like high 4's.
MarchGTR may of beaten the LS2 by that many car lengths to that speed as he said. No offence intended.
My question is when someone says they beat a car by a certain number of car lengths it's accuracy can be questionable because it's difficult to determine when the other party has actually hit the brakes.
Yeah maybe it was auto Pus. I dont' know much about twin turbo supras.
Mate of mine has a manual supra 6sp man aftermarket cooler and exhaust running 12psi of boost. Raced it expecting to get flogged but it turned out to be quiet the opposite on both rolling and standard starts I was very surprised the skyline just kept pulling away but I then again they do weight even more than a GTR.
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
