  • Replies 41
Nothing... I can't drive the bloody thing.
What I did at the same time as hitting a rock with the sump (well... just after it anyway) was driving it on a dirt road (done many times before but previously always on semislicks) on normal tyres, hooked it around a tight left hander with some handbrake at the same speed I'd done before but it slid a tiny bit too far out and smacked the right rear wheel into the bank.
This was just after I'd heard something smack under the car on an uneven bit of road, but there was no knocking from the engine, pulled over just down the road, saw there was rocks and shit embedded between the wheel and tyre but didnt notice the wheel was in until I'd gotten it home. Noticed the knocking from the FJ when I pulled over to check the wheel, switched it off, checked under the car for oil leaks, checked the oil, put more in for good measure. No mobile reception, no houses, after midnight on a weekday... SH1T!!!!!! Decided if i could drive it at very low revs a max of a km I could get it to a position that I could probably roll it home, or at least push it as there would be no more uphill bits, so I did that. Knocking got a tiny bit louder for the short time it was running (figured if it was stuffed it would need a rebuild or replacement anyway...)
Got home, jacked it up to take the weight off the tyre as I felt it could go flat from an imperfect seal, had felt flattish rolling home, back was swinging a bit but didnt look like it had gone down much. I didnt want to bend the rim of the Watanabe so I stuck an Enkei on the next day, noticed the wheel was sitting in a bit on an angle but thought some might have been from jacking the car up, rolled it up and down the driveway a bit to try and get it to settle but it didnt do terribly much.
Then I rolled it into the shed and forgot about the car until I went to get something from the shed the other day.
So I've bent something..... just dont know what it is yet
Only time I've ever hit anything btw... and I wasnt going quick at all, just like using the momentum of the car to bring the back out a bit on that corner, the dirt road is a bit of a shortcut between two good roads in the hills
I folded a wheel under my car putting it up a curb. I just payed a visit to jaustech they had a couple of arms laying round $150 which was a bit sore on the old pocket though.
However since then I have had a bit of a look at the wreckers and so on and from what I can see the mr30 sedan disk rear end is wrong on the caliper to rotor offset, however hatch back rear calipers fit on the rear DR30 arm and disc assembly which leads me to believe the hatch rear arms will fit up no worries, how ever I have never actually tried. If that makes any sense to you.
Hmmm, took the DR out of the garage and swapped the wheels off it so its sitting on the 16's and had a look under the back. I couldnt really see what was bent, it might be the arm where the axle goes through, it looks a little bit like the arm is bent in where it meedts the hub. Though it could also be where the arm mounts off the chassis... I guess I'll need to go and get all the MR30 hatch arms and then compare everything
  • 3 months later...
Engine is running now, so I just need to get the back fixed.
Took it to a suspension / alignment dude yeasterday and he said that the arm probably needs to be replaced.
From what Bensdr30 said, the MR discs are smaller than the DR ones... but if the DR disc will bolt ono a MR hatch rear then that should be fine? I'll try Jaustech first for some DR arms I think
Adam,
The basic arm is IDENTICAL, it mounts to the same place, they are both interchangeable, BUT as Ben says, the rear brakes on the MR are different, they are only 254 instead of 290, the caliper mounts may be different as well.
The DR rear arms are unique as the HR's are same as MR & I just chucked a pair out yesterday. The original arms off my PNV, gone to the recyclers.
I have a pair of stock HR calipers here as they are very similar to DR. I will check tomorrow if the calipers can be mounted to the DR rear end etc and advise further.
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
