Hello everbody my name is Adel I am rebuilding my RB26 engine on my GTR R34 and I am looking for the engine tightening torque, can anybody please give the right torque tightening starting from the head studs to the bearings, am going to use 88mm pistons and the rest.
Awaiting for an answer as soon as possible please.
:bs!: :bs!:
Best Regards to all
https://www.sau.com.au/forums/topic/73188-rb26-engine-rebuild/
I assume they are the same for any RB26? I've just rebuilt mine using 88mm pistons as well and can give you the torque settings we used, though mine's an R32.
Tighten to 29 Nm
Tighten to 108 Nm
Then loosen all bolts completely
Tighten all to 29 Nm again
Finally tigten all to somewhere between 103 to 113
Thank you man,,
Am using single turbo HKS T51R-SPL and HKS Cams 272 deg in/out do you have any special tricks or setings to gain mor power? or what will be the best timing set up,
Adel
Tighten to 29 Nm
Tighten to 108 Nm
Not at the moment. It's still sitting on the engine stand. Hopefully drop it in this weekend and tune it during next week. As for now my turbos and cams are still stock. I've done the rebuild first (was sort of forced to, stuffed the last block) and will then add some meaty cams and bigger turbos.
One thing for sure, it will be tuned very much on the safe side at first and then I'll try and clock up some quick kays at low boost to run it in. Will get back to you once I start trying to milk some power. I was running 320rwkw but that was on very high boost. How the standard turbos didn't shit themselves I'll never know.
Hey Matt,,
My mechanic is asking few questions like
1. Can the head Bolts be reused ?
2. Can the Con Rod bolts be reused ? both are in good condition though.
3. How do you start tightening the head bolts? he means do you start from the center bolts then back to fwd or what is the best way, coz again he works with ferraries and its his first time to work with the RB26 enigine.
4. Head bolts torque
5. Main bearings torque
6. Con Rod bearings
7. Cam shaft caps
8. Flywheel torque
Sorry Matt for being a Pain but its imprtant to me.
Thank you
Adel
Yes
Yes
Middle, then fwd, back, fwd, etc till you reach the outer bolts
Sorry, just reread your first question in this thread. Those settings I gave you are for the head bolts.
6. Con Rod bearings
7. Cam shaft caps
8. Flywheel torque
I will post these later today, I don't have them at hand.
mate, do a search on here for "R32 Workshop Manual", there is a full copy posted in english with all torques and tightening orders, everything you need :)
I reused the head bolts but replaced the rod bolts. But unless you are a real tightarse just replace both, better than pulling it all apart again later
That's where I'm getting the settings from, the r32 workshop manual.
I suppose I should have replaced the rod bolts but 'meh', they'll do. It's nothing to do with being a tight arse (hell, I've spent 12 grand on just engine parts not including turbos), it was more to do with couldn't be arsed.
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
