my r32 seems to not want to idle below 2,000 rpm originally my throttle body would stick when the idle pin was screwed in( too lower the idle below 2,000 rpm) I have replaced the throttle body and it no longer sticks but still sits at 2,000 rpm. I have gone through idle adjustment procedure and the ecu section seems to do nothing on my car and the valve control only lowers it to 1,500 rpm or so. I then cleaned the valve as suggested by others this seemed to work for a little while(sat at 1,200 rpm) as the car warmed up it rose very slowly back up to 2,000 rpm. Please help ps my car was auto to start with but idled at 2,000rpm in park then too.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/
check this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=69151
seems like this is fairly common, mine does it aswell. im gona fix the air regulator soon
im pretty sure the air regulator is my problem cos if i take it out for a drive and it really warms up the idle eventually falls down to about 1000. I haven't fiddled with my screw yet but i will once i get to to start idleing around 1000 to get it down to 750'ish.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1344500
From memory, the resistance (ohms) between pins 1 & 2 (the top 2) should be 0 when the throttle is closed.
A quick check would be to remove the plug while the engine is running, and short the 2 pins on the loom side with a paperclip. If the revs suddenly drop, then you need to adjust the TPS.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1345737
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
    • What is the current snail?
    • Never an issue with boost control. No weird boost issues pre throttle at partial throttle like you're suggesting. It worked.   As for all the turbo damage claims, they all were started by aftermarket BOV companies. At least turbo timer companies had SOME truth about them, except people failed to realise that except for in extreme circumstances, that small amount of driving you do to park/ through pit lane etc, is enough to not have a need for a turbo timer.
    • I tell people all the time this stuff runs on a 2 MHz 8-bit MCU. The math is a bit arcane, they do a lot to get around their limited resolution and so on but it works great as-shipped. So if an 80 to 160 MHz modern 32-bit MCU can't make it work you've really screwed something up badly. Your average graphing calculator is faster these days, god forbid we start talking about what's hiding in vapes or some stupid internet-connected "smart appliance".  I suspect the lore about off-throttle surge damaging turbos must be very, very old if it was ever true. I still don't think off throttle surge is good for turbos because you're rapidly having air going in and out of the turbo on top of rapid loss in shaft speed which presumably does impart some kind of unusual load on the rotating assembly. As for the recirculating valve, I believe Nissan actually in a press slide deck of some kind explained for the RZ34 they found it improved response. Prior to that they kept the throttle cracked open instead which causes rev hang and because the throttle/engine is a substantial restriction a ton of the energy in the air stream is lost just to pumping past it. Recirculating helps reduce energy loss by bringing the intake side of the compressor up in pressure so it's not working as hard to pull air in. In DCT cars where they can slam gears I believe Porsche hangs the throttle wide open with no fuel injection to keep turbo RPMs as high as possible during the shift. As for running post-throttle boost source, I would be concerned that at partial throttle on boost you would have driveability issues. It would be constantly trying to run crazy amounts of boost before the throttle to compensate for the throttling effect. Maybe with a much more sophisticated boost control setup you could activate a solenoid that goes from a conventional 3-port setup to something that allows the wastegates to see full vacuum in that specific case?
    • Did you clean everything out? Take all intercooler piping off, empty the intercooler of oil, clean the exhaust out, etc? Intercoolers make great catch cans... Which makes them less useful for intercooling... But very worth cleaning out, along with all adjoining piping.
