i will buy the head seperate to the plenum and throttle bodies but i cant buy for at least 2 months let us know IN5AN3 and muaythailuke what you want to do.
If you guys and organise something between you it doesnt worry me, but I would need a deposit from you s13drifter if you cant pay in full for 2 months just so I know you'll be back for the head. :(
Hi guys,
Im in need of cash so im selling some stuff I had lying about, some I dont really want to sell but gotta.
*Complete RB26DETT head! comes with cams, gears, valves, springs, cam covers, plenum, throttlebodys etc. dont know what model it is from but in good condition.  $1800
*Set of DUNLOP FORMULA SS001 tyres BRAND NEW!! never been fitted to a rim.  size is 235/45 17's $1000 worth over $400 each
*Quick Release Hub for aftermaket steering wheel, sparco brand $150
*Spacer for aftermarket steering wheel, screws in and out for custom fitment! $120
*R33 GTS-t rotors! ok condition SOLD!
*R33 GTS-t fuel pump. Came out of my car with about 70,000km's on the clock $50
*RB25DET standard exhaust manifold and dump pipe + heat shields if you want them $120
*RB25DET radiator! a few bent fins but works perfect. Core only replaced about 2000km's ago SOLD!
*RB25DET coil packs, good condition never had any trouble with them. $70 each
*Kakimoto 3" Cat back exhaust with stainless muffler $350
still on car will remove soon to take photo.
plus a couple of other standard engine parts like injectors, turbo intake pipes. PM me if you want more info on these or any of the other parts.
Will have pics up soon!!
Also have a KHS mountain bike For Sale!
Hi can you call me on 0414500058 ,i want some of your gtr parts ,thanks mate.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
