r these bigger then the stock rotors ????
and if not how do they help inrease stopping power ?
As per the DBA web site:
"Some of the secret ingredients of a DBA 4000 series disc rotor"
'Kangaroo Paw' is a patented hi-tech disc rotor ventilation system, designed and manufactured in Australia by Disc Brakes Australia. Not available on all part numbers, please check with your supplier for availability.
More info:
http://www.dba.com.au/dba_catalogue_2004/H...s/paw_index.htm
TSP is a propriety process specifically developed by DBA for improving the performance of disc brake rotors.
More info:
http://www.dba.com.au/dba_catalogue_2004/H...s/tsp_index.htm
Thermo-Graphic’ markings are placed on the outer edge of each DBA 4000 / 5000 series disc rotor and are used to monitor the core temperatures that are achieved during braking application. All DBA 4000 / 5000 series rotors include 'Thermo-Graphic' markings.
more info:
http://www.dba.com.au/dba_catalogue_2004/H...Information.pdf
The directional slots allow for "deglazing" of the pad giving a better "bite" and most rotors are slightly oversize (only marginally so factory calipers still bolt on)
which acts as a better heat sink to reduce thermal stress of performance pads in sports driving.
In addition the rotors are made of a heavy duty material so perfmance pads wont quickly wear the rotor or warp them in hard driving.
Dont want Amosite to think im ripping him of buyers but just to let people know.
I recently pickup up a pair of r32 gtr dba 4000 rotors for $198 each. That was the retail price from my local Repco in sydney! I was shocked too when he told me how cheap it was.
As for prices for other rotors, i would have no idea.
Ok, I just got off the phone to a couple of repco outlets and tehy said that
4926 SL (R32 GTR 4000 Series slotted) are $268.
So they must have stuffed up on your order, or supplied you something different, lucky you! :P
But please, feel free to check prices with local distributors.
Hi,
Im interested in the R32 GTR 296mm x 32mm slotted rotors. But I want to fit these to a R33 GTS-4. Do they come pre drilled or will they drill them to suit my application? Will this be the same price?
Hi,
I dobt they will fit as the GTS4 has 280x26 disc. The size increase seems on the high side.
Unless you had R32 GTR Calipers I dont think you could run a 296x 32 disc.
DBA make a direct replacement for your car, cost is about $175 each
Im planing on a brake upgrade. Ive got r32 gtr calipers and rotors here but the rotors arnt much chop.
I just dont want to have to get them re drilled to fit
I can get blanks but DBA wont do special orders.
Getting them drilled for 4x114.3 would be $50 each..
The other opotion you have is a 5 bolt hub kit
Unique Auto Sports have em (www.nismo.com.au)
DBA 4000 SERIES BRAKE ROTORS FOR SKYLINE R33 GTS-T
KANGAROO PAW SLOTTED ROTORS. THESE ROTORS ARE HEAT TREATED WITH THERMO PAINT INDICATORS.
CROSS DRILLED ALSO AVAILABLE FOR AN ADDTIONAL $30.00 PER ROTOR
CLICK HERE FOR MORE INFORMATION
PRICE: $240.00 EACH
And lasty i shopped there, i received 10% of for being a Skylines Australia member. (ie $216)
So if your picking up, that would be the way to go...although sometimes their web prices could be a bit outdated.
  • 1 month later...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
